I just wanted to have an alert pop up but want multiple lines. How do you make the text return to the right?
example:
(alert "Hi /p How are you?")
result:
Hi
How are you?
(alert "first line\nsecond line")
example:
result:
Hi
How are you?
If you have list of text lines this will helps
(defun build_alert (lst / text)
  (alert
    (substr
      (setq text
      (apply 'strcat
      (mapcar
        '(lambda (x)
    (strcat x "\n")
        lst
      1
      (1- (strlen text))
;;usage
(build_alert '("alpha" "bravo" "charlie" "delta" "echo" "fixo"))
~'J'~
(defun build_alert ( lst / lst->str )
 (defun lst->str ( lst del )
   (if (cdr lst)
     (strcat (car lst) del (lst->str (cdr lst) del))
     (car lst)
 (alert (lst->str lst "\n"))
:unsure: :huh:
Laughing at the two of you over complicating a simple question.
Thanks guys! I did go with /n
How do I add " in LISP?
Example: I'm overriding a dim and I'm inputing "w/nx6'-8"h
I can get the words in but " throws my routine all off.
Thanks! I'm trying to write LISP routines. Trying
