I have had a chance to take another look as to what is going on. I would recommend combining the two codes "kast" & "front" into one function. If you wish to enter two points for your distance then just be careful where you are selecting. I have been entering the dimensions as numbers rather than two points. All is seemingly working for me with the exception of some minor changes to the polar comps to fix the offsets and what not. I'll say again that you need to edit your block dwg so that the insert of the block is at 0,0. The problem you seem to be having is most likely a blunder. Have your code print the dimensions that you enter to the screen so that you are able to see any input mistakes that may make. Let me know how it goes.
Regards,
Hippe013
  • Replies 21
  • mitchellrodhous
    10
  • Hippe013
    9
  • MarcoW
    3
Posted Images
Well I dicided just insert on node-point on de ip of this object so I can easely click the box and hingles near to my cabinet. That's the best solution I can think of it...probebly it has something wo do with the Z.. Just need a bit more experiece with creating lisp... After All thanks for help,
Regards MR
