chulse Posted June 10, 2010 Posted June 10, 2010 Given a specific block, how might I retrieve it's X, Y and Z coordinates, then move it's Z value to a specific depth (while keeping the x and y the same)? Thanks Quote
fixo Posted June 10, 2010 Posted June 10, 2010 Given a specific block, how might I retrieve it's X, Y and Z coordinates, then move it's Z value to a specific depth (while keeping the x and y the same)? Thanks Something like this will helps: (command "._move" block_entity_selected "" '(0 0 0) (list 0 0 Z)) ~'J'~ Quote
chulse Posted June 10, 2010 Author Posted June 10, 2010 Thanks Fixo, Perhaps I need to clarify a bit - I need to add the value of a variable "depth" to the current Z value, and set that as the new Z value. I didn't think I could do that using a command call...? Quote
VVA Posted June 10, 2010 Posted June 10, 2010 then so (setq Z (getreal "\nEnter delta Z value: ")) (princ "\nSelect block") (setq ss (ssget "_:L" '((0 . "INSERT")))) (command "_.MOVE" ss "" "0,0,0" (strcat "@0,0," (rtos Z 2 15))) Quote
fixo Posted June 10, 2010 Posted June 10, 2010 Thanks Fixo,Perhaps I need to clarify a bit - I need to add the value of a variable "depth" to the current Z value, and set that as the new Z value. I didn't think I could do that using a command call...? Here is Q&D example Try it also (defun C:MZ (/ elist en sset zv) (setq zv (getreal "\nEnter a Z value to add to an existing Z value: ")) (princ "\n >> Select block instance >>") (if (setq sset (ssget "_:S:E:N" '((0 . "INSERT")))) (progn (setq en (ssname sset 0)) (setq elist (entget en) ptlist (assoc 10 elist) ) (entmod (subst (cons 10 (list (car (cdr ptlist)) (cadr (cdr ptlist)) (+ (last (cdr ptlist)) zv))) ptlist elist) ) (entupd en) ) ) (princ) ) ~'J'~ Quote
chulse Posted June 10, 2010 Author Posted June 10, 2010 Thanks for your help Fixo I'm sure there are better ways, but I ended up with this before the block insertion: (setq x (car pt)) (setq y (cadr pt)) (setq Z1 (caddr pt)) (setq Z2 (+ depth Z1)) (setq PT2 (list x y Z2)) Quote
fixo Posted June 10, 2010 Posted June 10, 2010 Thanks for your help Fixo I'm sure there are better ways, but I ended up with this before the block insertion: (setq x (car pt)) (setq y (cadr pt)) (setq Z1 (caddr pt)) (setq Z2 (+ depth Z1)) (setq PT2 (list x y Z2)) You're welcome Happy computing ~'J'~ Quote
chulse Posted June 10, 2010 Author Posted June 10, 2010 You're welcomeHappy computing ~'J'~ Ha, Let's call it "Happy LEARNING!" Thanks Quote
BIGAL Posted June 11, 2010 Posted June 11, 2010 Easier still if you know the elavtion required before you insert the block just "Elevation" "Elev" and set value dont forget though set it back to 0.0 Quote
chulse Posted June 11, 2010 Author Posted June 11, 2010 Easier still if you know the elavtion required before you insert the block just "Elevation" "Elev" and set value dont forget though set it back to 0.0 I don't in this case. I only know the depth below surface. The elevation is taken fromt he point on a 3D Pline - then moved below it. ...I just realized I am adding in my code where I need to subtract... Quote
alanjt Posted June 12, 2010 Posted June 12, 2010 What about the Change command? Command: change Select objects: Specify opposite corner: 1 found Select objects: Specify change point or [Properties]: p Enter property to change [Color/Elev/LAyer/LType/ltScale/LWeight/Thickness/Material/Annotative]: e Specify new elevation <25.0000>: 52 Enter property to change [Color/Elev/LAyer/LType/ltScale/LWeight/Thickness/Material/Annotative]: For fun... (defun c:BEC (/ elev ss) (if (and (setq elev (getreal "\nSpecify elevation : ")) (setq ss (ssget "_:L" '((0 . "INSERT")))) ) ((lambda (i / ent) (while (setq e (ssname ss (setq i (1+ i)))) (setq ent (entget e)) (entmod (subst (reverse (cons elev (cdr (reverse (assoc 10 ent))))) (assoc 10 ent) ent)) ) ) -1 ) ) (princ) ) FYI: a double reverse for each object is incredibly inefficient, but for a 4 item list, I figured I'd do it anyway. What's life without a little whimsy? Quote
chulse Posted June 14, 2010 Author Posted June 14, 2010 Interesting - always more than one way to do anything Quote
alanjt Posted June 14, 2010 Posted June 14, 2010 Interesting - always more than one way to do anything Only hurts the cat. Quote
