Select again last selected objects
How to select last selected objects that I manualy clicked?
It is very slow work to select them again.
Than you.
There are 2 ways I do this:
1. Go into a command (eg ROTATE), then when it asks you to select objects, then type "P" for previous selection set, then right click to confirm that set, and carry on your command as normal.
Or 2. If you need to change the properties, not just perform a command on the set, then use the button to the left of the QUICKSELECT button at top of properties box.
It is PSELECT, (the button looks like a white square with a mouse pointer and a red cross) and again you can then type "P" and enter; and enter again if you do not want to add any more to the set.
I suspect there's also a SETVAR which dictates whether a right click would bring them back up
Thank you Isaac James for your help. That is what I wonted to know.
There is something strange in this command for me.
I have made button for it: ^C^C_PSELECT;P;
_______________________________________________-
When I open new drawing and press the buttom this happend:
Command: _PSELECT
Unknown command "PSELECT". Press F1 for help.
___________________________________________________________
in this step I have to open panel properties and close it. After it when I select something (previous selection it does not remember) the button start to work OK.
Command: _PSELECT
Select objects: P
2 found
Select objects: Specify opposite corner: 3 found (2 duplicate), 3 total
________________________________________________________________
It seems that command pselect is not loaded in Autocad or memory untill is opened propertis panel. So this command is not too handy. I am using Autocad 2007 full. How can I improve this commant to start to work from the begining? (I have tryed it by my colleague and it behaved by the same way.)
Well, I have the properties box sitting open on the left of my screen all the time. I make extensive use of it constantly. So the PSELECT was just always available.
As to creating buttons, that is something I am not familiar with, so hopefully someone else can give you some guidance on that one.
Command: _PSELECT
Command: _PSELECT
Select objects: P
2 found
pselect requires an arx to be loaded (can't remember name), just use select: ^C^C_SELECT;P;
that should get you what you need.
acopm.arx is the arx file you have to load for pselect to work
try this: ^C^C(arxload "acopm.arx")_PSELECT;P;
