The fractions text in my dimensions appears too large. They are most likely the same text height, but for some reason they look odd. Also, the fraction looks like it's too close to the preceding number 4.
Please see attached:
DIMS.dwg
I assume 2006 has the setting for fraction height scale. Start the dim style manager(ddim at the command line), text tab, find Fraction height scale, set it smaller.
At the command line:
DIMSTYLE > TEXT> Fraction height scale
Adjust OK, Set Current :wink:
DIMS[1].dwg
Thanks to both. Do you see how close the fraction is to the 4 though? I think it looks odd. How does it look to you?
I prefer 5/16". Adjust DIMSTYLE > Primary Units >
Fraction format now reads "Horizontal", change to "Diagonal."
Apply, backing out, Set Current.
Does that look better?
For the heck of it, try "Not Stacked." How's that?
I like not stacked. Thanks Tankman.
Glenn
Glenn
To my liking too!
Where are you posting from? Just curious.
To my liking too!
You must have missed it when I told you last. St. Pete, Florida. Where it's as hot today as the :twisted:.
