NTX JK Posted June 11, 2010 Posted June 11, 2010 My printer recently started to print out of alignment. How can I fix this? How the print is suppose to look: What the print actually looks like: Quote
Dana W Posted June 11, 2010 Posted June 11, 2010 Is that a printer or plotter? Try the print head alignment utility that comes with the printer, if there is one. Of course, it could be a hardware problem which may call for printer service. Quote
NTX JK Posted June 11, 2010 Author Posted June 11, 2010 Sorry, it is a plotter. it is a HP Designjet 650C. It is too old to call for support. I can't even pay to get support. Quote
Dana W Posted June 11, 2010 Posted June 11, 2010 Sorry, it is a plotter. it is a HP Designjet 650C. It is too old to call for support. I can't even pay to get support. Well, to me it looks like a hardware problem, but there is an off chance that updating the plotter driver might help. Go to the HP site and look for an update. I don't know anything in AutoCAD that might cause that. Any suggestions of what might be wrong with the plotter in a hardware way would just be guesswork on my part. It looks like the return pass of the print head is off alignment by 1/4" or so. Quote
nukecad Posted June 13, 2010 Posted June 13, 2010 . It looks like the return pass of the print head is off alignment by 1/4" or so. I agree, it loooks like a problem with backlash on the print head drive belt. Could be a loose screw on one of the drive pulleys, or could be that there are teeth missing / worn out on the belt. From looking at your plot I would say that the loose screw is more likley; try taking the front cover off and tightening the screws that hold the pulleys; check the belt for missing teeth whilst you are at it. Quote
