Tharwat Posted June 12, 2010 Posted June 12, 2010 Hi Everybody, How can I stop running an Autolisp program when user intend to press . For examlpe; (defun c:ib (/ a count) (setq a (cdr(assoc 2 (entget(car(entsel"\nSelect a Block: ")))))) (setq count 1) (while count (command "_insert" a pause "" "" "" )) (princ "Written by Tharwat") (princ)) Regards, Tharwat Quote
David Bethel Posted June 12, 2010 Posted June 12, 2010 Hi Everybody,How can I stop running an Autolisp program when user intend to press Maybe like this: (while (setq ip (getpoint "\nInsert Point - (Enter To Exit): ")) (command "_insert" a ip "" "" "" )) -David Quote
Tharwat Posted June 12, 2010 Author Posted June 12, 2010 Maybe like this: (while (setq ip (getpoint "\nInsert Point - (Enter To Exit): ")) (command "_insert" a ip "" "" "" )) -David Hi Mr.david You said maybe and that was perfect, and what's if you were sure . Thank you so much . Tharwat Quote
David Bethel Posted June 12, 2010 Posted June 12, 2010 Tharwat, The drawback this is scenario is that you are not seeing the block insertion ( dragmode ) Not always necessary but it can be helpful in certain conditions. -David Quote
Tharwat Posted June 12, 2010 Author Posted June 12, 2010 Mr.David, Yes I do agree with you. Tharwat Quote
BIGAL Posted June 15, 2010 Posted June 15, 2010 I use a check for nil in my loops make it your last line in the while (setq x (getint "\n Enter number to exit)) ;1st time pick (while (x nil) ;x is not nil CR pressed etc etc (setq x (getint "\n Enter number to exit)) ; last line before endwhile ( ; endwhile Quote
woolenthreads Posted August 2, 2018 Posted August 2, 2018 All I can say is "Thank You". I've been perusing the web intermittently for a couple of weeks looking for the answer and trying things which failed. I kept running into this one but without a clear understanding of how it worked (or enough understanding of how any of them worked really). It was only a reference in another forum that gave me a clue as to how to apply this answer to my immediate problem. Quote
