Is There Any Way Let Lisp Work Automatically When Autocad Start?
Plenty of ways.
"acad.lsp" is loaded once per AutoCAD session (unless ACADLSPASDOC =1)
"acaddoc.lsp" is loaded once per drawing session.
For any menu that loads, if there is an ".MNL" file with the same name as the menu, it is loaded.
There are other ways also, but it may depend on what your lisp is set up to do, and when you want it loaded. Remember, in the case of conflicting lisp definitions, the last to load wins.
See also:
http://rkmcswain.blogspot.com/2006/07/autocad-customization-setup-and.html
http://www.blog.cadnauseam.com/2008/09/01/what-is-loaded-at-autocad-startup-and-when/
Do you mean for the LISP to be loaded when AutoCAD starts, or for the LISP to run when AutoCAD starts?
Because, if you want the LISP to automatically be loaded, you could always use the 'Startup Suite' under the 'Load Application' dialog box. (_appload)
That makes no difference in how you load the code. For example:
;;; this will load the function "foo" and execute it
(defun c:foo ()
 (alert "Hello World")
(c:foo) ;;;<- take out this line to just load the function definition
;;; this will execute the same code without defining a function.
Although the startup suite generally works, this is a poor choice. There is no way to automatically migrate these items to another machine or during a upgrade. The startup suite is also known to fail to load or sometimes double load items. "Acaddoc.lsp" is a better choice since you can just dump this file in the top path of your support file search path, on any machine.
THANKS GUYS FOR YOUR REPLAYS, REALLY I WANT the LISP to run when AutoCAD starts?
Then put your code in "acad.lsp" like this:
[color="SeaGreen"];;; begin acad.lsp[/color]
[color="Red"]([/color][color="RoyalBlue"]put your code here[/color][color="Red"])[/color]
[color="Red"]([/color][color="RoyalBlue"]more code[/color][color="Red"])[/color]
[color="Red"]([/color][color="RoyalBlue"]even more code[/color][color="Red"])[/color]
[color="seagreen"];;; end acad.lsp[/color]
If this file does not already exist (it does not come with AutoCAD), then create a new one using Notepad or use the VLIDE editor built into AutoCAD.
If you actually want the code to execute each time a drawing is loaded, then use the "acaddoc.lsp" file instead.
If You Load Lisps This Way Does It Take Up Lots Of Space On The Hard Drive?
How Many Should You Use ???
Also Can You Create Custom Buttons ???
(setq oldfiledia (getvar "FILEDIA"))  ;Save value of FileDia system variable
(setvar "FILEDIA" 0)                  ;Set FileDia to 0 to use command prompt only
(setvar "FILEDIA" oldfiledia)         ;Set FileDia back to previous value
(setq oldfiledia nil)                 ;Clear variable used for FileDia
What is that supposed to accomplish?
THATS WHAT WAS IN MY ACAD DOC LISP FILE WHEN I GOT ON THIS COMPUTER .
Regenerating model.
AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc.
_.menuunload
Enter the name of a MENUGROUP to unload:DWGGATEWAY
Menu unloaded successfully. MENUGROUP: DWGGATEWAY
_.menuload dwggateway.mns
Menu loaded successfully. MENUGROUP: DWGGATEWAY
THIS IS WHAT COMES UP AFTER I START ACAD . ANY IDEAS IF I SHOULD ERASE SOME OF IT ?
Regenerating model.
_.menuunload
The code you posted has nothing to do with the text results above. The code does nothing.
If It Does Nothing Than Ill Erase It . Right On
I Had A Hard Time Finding My Acaddoc.lsp File Too. Mainly Cause It Was Hidden In A Applications Folder . Also
There Were 2 Of Them. My Advice Would Be To Make A New One Write Smalle Code Aka (setvar "***") And See If The Variable Changes . Or Try To Find It Using Search . And If All Esle Fails Just Hire Someone.........
Good Luck ...
...........................best Forum Ever......................
You don't have to guess. AutoCAD will load the first one it finds by searching the support file search path, in order, (and only the first one).
Paste this to the command line (findfile "acaddoc.lsp") - that will tell you the location of the "acaddoc.lsp" file that AutoCAD is using.
