Proctor Posted June 14, 2010 Posted June 14, 2010 Hello: I want to modify the color of some lines I created earlier in my subroutine, but it's not working. Earlier in the sub, I call DrawLines to draw the lines (working fine): Public Shared Function DrawLine(ByVal pStart, ByVal pEnd, ByVal sColor) As Line Dim myTransMan As Autodesk.AutoCAD.DatabaseServices.TransactionManager Dim myTrans As Autodesk.AutoCAD.DatabaseServices.Transaction Dim myDWG As Autodesk.AutoCAD.ApplicationServices.Document Dim myBT As Autodesk.AutoCAD.DatabaseServices.BlockTable Dim myBTR As Autodesk.AutoCAD.DatabaseServices.BlockTableRecord 'Get the active document and begin a Transaction myDWG = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument myTransMan = myDWG.TransactionManager myTrans = myTransMan.StartTransaction 'Open the BlockTable for Read myBT = myDWG.Database.BlockTableId.GetObject( _ Autodesk.AutoCAD.DatabaseServices.OpenMode.ForRead) myBTR = myBT(Autodesk.AutoCAD.DatabaseServices.BlockTableRecord.ModelSpace).GetObject( _ Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite) 'Draw the line Dim myLine As New Autodesk.AutoCAD.DatabaseServices.Line(pStart, pEnd) 'was this line already just drawn? Select Case sColor Case "YellowGreen" myLine.Color = Autodesk.AutoCAD.Colors.Color.FromColor(Drawing.Color.YellowGreen) Case "Pink" myLine.Color = Autodesk.AutoCAD.Colors.Color.FromColor(Drawing.Color.Pink) Case "Purple" myLine.Color = Autodesk.AutoCAD.Colors.Color.FromColor(Drawing.Color.Purple) Case "Blue" myLine.Color = Autodesk.AutoCAD.Colors.Color.FromColor(Drawing.Color.Blue) Case "Coral" myLine.Color = Autodesk.AutoCAD.Colors.Color.FromColor(Drawing.Color.Coral) 'small lines used just to see if the merge is correct - temp lines Case "Gold" myLine.Color = Autodesk.AutoCAD.Colors.Color.FromColor(Drawing.Color.Gold) Case "Red" myLine.Color = Autodesk.AutoCAD.Colors.Color.FromColor(Drawing.Color.Red) End Select myLine.Layer = 0 myBTR.AppendEntity(myLine) myTrans.AddNewlyCreatedDBObject(myLine, True) DrawLine = myLine 'Commit the Transaction myTrans.Commit() myTrans.Dispose() myTransMan.Dispose() End Function Later, I want to modify the color of the lines I drew, so i try to do something link this: For m As Integer = 0 To myListOfEdges.Count - 1 Edge = myListOfEdges.Item(m) Debug.Print("edge: " & Edge.sTypeEdge.ToString()) Debug.Print("line len: " & Edge.dTotalLengthOfLines.ToString()) If Not IsNothing(Edge.lstLinesInEdge) And Edge.sTypeEdge.ToString() = "secondary" Then For j As Integer = 0 To Edge.lstLinesInEdge.Count - 1 Dim oLine As Line = Edge.lstLinesInEdge(j) Debug.Print("line len: " & oLine.Length.ToString()) 'main line that attempts to change color of line: [color=red]oLine.Color = Autodesk.AutoCAD.Colors.Color.FromColor(Drawing.Color.Green)[/color] Next End If Next tr.commit After the subroutine finishes and I can see the drawing in cad, the color of the lines didn't change. I try doing a regen to refresh the screen, but the color of the lines still haven't changed. I'm wondering what am i missing? Thanks, Proctor Quote
StevJ Posted June 14, 2010 Posted June 14, 2010 You might have to use color numbers instead of color names. chroma.dwg Quote
Proctor Posted June 14, 2010 Author Posted June 14, 2010 Hi StevJ: Thanks for your reply. I went to try that; however, the intellisense for the FromColor() method pops up and has me pick out a Drawing.Color from it's list so I believe that parts ok. Thanks again for your help, Proctor Quote
SEANT Posted June 15, 2010 Posted June 15, 2010 Is the Line contained within Edge.lstLinesInEdge(j) already database resident. If so then it would typically need to be OpenMode.ForWrite before any of it’s properties can be changed. I suppose it is not impossible to have a collection of “Open” database resident objects, but that sound a bit risky. Does the routine’s objective require dealing with entities in that fashion? Quote
BIGAL Posted June 15, 2010 Posted June 15, 2010 I agree with stevj if your going to play around with colours its a lot easier to use the numbers then you don't have to strart remembering two different colour systems AcRed v's 1 AcYellow v's 2 also when you start using more than color 9 its easier to remember 20 32 50 140 (we plot in b&w plus colour) red orange yellow lightblue Quote
Proctor Posted June 15, 2010 Author Posted June 15, 2010 Thank you all for your help. I hope you don't mind but, I think I'd like to back the truck up a bit...because I'm now thinking that perhaps I'm confused in regards to what exactly needs to happen when creating lines. 1) My code starts asks the user to select a poly and then it locks the document and starts a transaction: If Not IsNothing(myPSR.Value) Then Using docLock As DocumentLock = myEd.Document.LockDocument() Using tr As Transaction = myDB.TransactionManager.StartTransaction() 2) It then loops through each of the poly vertecies and creates lines: For i = 0 To pPoly.NumberOfVertices - 1 If i > 0 Then myLine = New Line(myPt, pPoly.GetPoint3dAt(i)) End if next I add these lines into a collection to be used later; At some point in my sub, I then want to display one of the lines in my collection. Originally, I was uncertain how to display the line....so I called my DrawLine routine. it takes in the line's start and end points as a parameter and is basically creating the line. but, isn't the line already created? This was the only way i was able to get the line to show up and now that I'm thinking about it....i don't think this is right. I think there must be some how to display the line created originally in my code (using code under #2). Thanks for your help.... Proctor Quote
Proctor Posted June 15, 2010 Author Posted June 15, 2010 ok..i just read that in order to draw the line ...when it's created, you need to add it to the block table record. so now, as i'm looping through and creating each line, I'm adding it to the block table record: [size=2][color=#0000ff][size=2][color=#0000ff]For[/color][/size][/color][/size][size=2] i = 0 [/size][size=2][color=#0000ff][size=2][color=#0000ff]To[/color][/size][/color][/size][size=2] pPoly.NumberOfVertices - 1[/size][size=2][color=#0000ff][size=2][/size][/color][/size][size=2]myLine = [/size][size=2][color=#0000ff][size=2][color=#0000ff]New[/color][/size][/color][/size][size=2] Line(myPt, pPoly.GetPoint3dAt(i)) [/size][size=2]CreateLine(myLine, [/size][size=2][color=#800000][size=2][color=#800000]"Red"[/color][/size][/color][/size][size=2])[/size] i modified my DrawLine so that i can pass in the line just created and add it to the btr: [size=2][color=#0000ff][size=2][color=#0000ff]Public[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Shared[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Function[/color][/size][/color][/size][size=2] CreateLine([/size][size=2][color=#0000ff][size=2][color=#0000ff]ByVal[/color][/size][/color][/size][size=2] myLine, [/size][size=2][color=#0000ff][size=2][color=#0000ff]ByVal[/color][/size][/color][/size][size=2] sColor) [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] Line [/size][size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] myTransMan [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] Autodesk.AutoCAD.DatabaseServices.TransactionManager [/size][size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] myTrans [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] Autodesk.AutoCAD.DatabaseServices.Transaction [/size][size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] myDWG [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] Autodesk.AutoCAD.ApplicationServices.Document [/size][size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] myBT [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] Autodesk.AutoCAD.DatabaseServices.BlockTable [/size][size=2][color=#0000ff][size=2][color=#0000ff]Dim[/color][/size][/color][/size][size=2] myBTR [/size][size=2][color=#0000ff][size=2][color=#0000ff]As[/color][/size][/color][/size][size=2] Autodesk.AutoCAD.DatabaseServices.BlockTableRecord [/size][size=2][color=#008000][size=2][color=#008000]'Get the active document and begin a Transaction [/color][/size][/color][/size][size=2]myDWG = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument myTransMan = myDWG.TransactionManager myTrans = myTransMan.StartTransaction [/size][size=2][color=#008000][size=2][color=#008000]'Open the BlockTable for Read [/color][/size][/color][/size][size=2]myBT = myDWG.Database.BlockTableId.GetObject( _ Autodesk.AutoCAD.DatabaseServices.OpenMode.ForRead) myBTR = myBT(Autodesk.AutoCAD.DatabaseServices.BlockTableRecord.ModelSpace).GetObject( _ Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite) [/size][size=2][color=#008000][size=2][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Select[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Case[/color][/size][/color][/size][size=2] sColor [/size][size=2][color=#0000ff][size=2][color=#0000ff]Case[/color][/size][/color][/size][size=2][color=#800000][size=2][color=#800000]"YellowGreen" [/color][/size][/color][/size][size=2]myLine.Color = Autodesk.AutoCAD.Colors.Color.FromColor(Drawing.Color.YellowGreen) [/size][size=2][color=#0000ff][size=2][color=#0000ff]Case[/color][/size][/color][/size][size=2][color=#800000][size=2][color=#800000]"Pink" [/color][/size][/color][/size][size=2]myLine.Color = Autodesk.AutoCAD.Colors.Color.FromColor(Drawing.Color.Pink) [/size][size=2][color=#0000ff][size=2][color=#0000ff]Case[/color][/size][/color][/size][size=2][color=#800000][size=2][color=#800000]"Purple" [/color][/size][/color][/size][size=2]myLine.Color = Autodesk.AutoCAD.Colors.Color.FromColor(Drawing.Color.Purple) [/size][size=2][color=#0000ff][size=2][color=#0000ff]Case[/color][/size][/color][/size][size=2][color=#800000][size=2][color=#800000]"Blue" [/color][/size][/color][/size][size=2]myLine.Color = Autodesk.AutoCAD.Colors.Color.FromColor(Drawing.Color.Blue) [/size][size=2][color=#0000ff][size=2][color=#0000ff]Case[/color][/size][/color][/size][size=2][color=#800000][size=2][color=#800000]"Coral" [/color][/size][/color][/size][size=2]myLine.Color = Autodesk.AutoCAD.Colors.Color.FromColor(Drawing.Color.Coral) [/size][size=2][color=#008000][size=2][color=#008000]'small lines used just to see if the merge is correct - temp lines [/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Case[/color][/size][/color][/size][size=2][color=#800000][size=2][color=#800000]"Gold" [/color][/size][/color][/size][size=2]myLine.Color = Autodesk.AutoCAD.Colors.Color.FromColor(Drawing.Color.Gold) [/size][size=2][color=#0000ff][size=2][color=#0000ff]Case[/color][/size][/color][/size][size=2][color=#800000][size=2][color=#800000]"Red" [/color][/size][/color][/size][size=2]myLine.Color = Autodesk.AutoCAD.Colors.Color.FromColor(Drawing.Color.Red) [/size][size=2][color=#0000ff][size=2][color=#0000ff]End[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Select [/color][/size][/color][/size][size=2]myLine.Layer = 0 myBTR.AppendEntity(myLine) myTrans.AddNewlyCreatedDBObject(myLine, [/size][size=2][color=#0000ff][size=2][color=#0000ff]True[/color][/size][/color][/size][size=2]) CreateLine = myLine [/size][size=2][color=#008000][size=2][color=#008000]'Commit the Transaction [/color][/size][/color][/size][size=2]myTrans.Commit() myTrans.Dispose() myTransMan.Dispose() [/size][size=2][color=#0000ff][size=2][color=#0000ff]End[/color][/size][/color][/size][size=2][color=#0000ff][size=2][color=#0000ff]Function [/color][/size][/color][/size] now, I'm going to try to change the line's color...I'll get back to you shortly...I just wanted to let you know where I'm at now. thanks, Proctor Quote
Proctor Posted June 15, 2010 Author Posted June 15, 2010 Well..that's what the issue was..bad code. now that i'm creating the line and adding it to the btr, i'm able to change the color using: colListOfLines(t).Color = Autodesk.AutoCAD.Colors.Color.FromColor(Drawing.Color.Blue) thanks again for helping me. Proctor Quote
Kerry Brown Posted June 16, 2010 Posted June 16, 2010 Proctor, a couple of things .. Have you read the AutoCAD .NET Developer's Guide http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer's%20Guide/index.html Have a look at Use Transactions with the Transaction Manager and Consider making better use of namespaces instead of doing so much typing ie if you have used Imports Autodesk.AutoCAD.DatabaseServices OR for C# using Autodesk.AutoCAD.DatabaseServices then this Autodesk.AutoCAD.DatabaseServices.BlockTableRecord.ModelSpace can become BlockTableRecord.ModelSpace at the end of the day, the code is easier to read and thats half the battle when starting. Quote
