emma_edi Posted June 15, 2010 Posted June 15, 2010 Hi, I really hope someone can help me, I am trying to draw a dashed boundary line around a road for work. I have 6 drawings that use this line. However in one of my drawings although all the lines have the same scale and thickness the gaps in between the dash is smaller. Typically this is the one that looks the best. Does anyone know what the problem might be? I cant use match properties as they are all on different worksheets within the one drawing. I have tried using match properties in the model space, but this makes no difference either. I would be really grateful for any help. Quote
ReMark Posted June 15, 2010 Posted June 15, 2010 Did you check the linetype scale in Properties to see what the various lines had been set to? Quote
edwinprakoso Posted June 16, 2010 Posted June 16, 2010 Check the LTSCALE and annotation scaling. This might be able to help: http://cad-notes.com/2010/06/controlling-linetype-scale-is-as-easy-as-123/ Quote
emma_edi Posted June 16, 2010 Author Posted June 16, 2010 Thank you, I've tried MLTSCALE and PLTSCALE and unfortunately all are set to one, for both drawings. Any other ideas? This is driving me mad!!1 Quote
edwinprakoso Posted June 16, 2010 Posted June 16, 2010 Have you checked the annotation scaling and the linetype scale in properties palettes? Quote
emma_edi Posted June 16, 2010 Author Posted June 16, 2010 Thank you for help, I ended up going back and starting from the begining. My computer is part of a huge network so maybe it was just some strange glitch! Got it sorted in the end though. Cheers Quote
