JimeeB Posted June 16, 2010 Posted June 16, 2010 I have looked through numerous FAQS and websites and was unable to find a solution. Okay, I am using Inventor 2010. My problem is, when I click on the dimension tab and hover over a line to dimension, NOTHING happens. Meaning that the line does not change color and I am unable to drag the dim line out. I have also noticed this same problem with with trim and extend, however with those two functions i can hover over a line and press ENTER and the command will execute. This is not the case with dimension though. I have noticed that if I shut down and restart the program half a dozen or so times it will eventually work. If ANYONE can help with this it will be greatly appreciated. I really dont want to uninstall and reinstall the program..... Thank you Quote
MarkFlayler Posted June 16, 2010 Posted June 16, 2010 What are your system specs? Some things to try... Update your video card driver Are you using OpenGL or DirectX on the Hardware tab of the Application Options? Did you have Antivirus off when you installed it? Quote
JimeeB Posted June 16, 2010 Author Posted June 16, 2010 Video card driver is up to date. Using Direct3D option. And I always disable A/V when installing any software. here is the message after running diag. This Direct3D graphics driver is not Microsoft WHQL certified Graphics Hardware Description: RADEON 9800 PRO Direct3D \ Hardware Renderer Graphics driver file ati2dvag.dll is version 6.14.0010.6925 Using Full optimization (this is the recommended setting) The display is using 32-bit color Inventor Version: Build: 253, Release: 2010 SP1 - Date: Wed 07/29/2009 32-Bit Edition - 2.00 GB Loaded Inventor Add-Ins: Assembly Bonus Tools Simulation: Dynamic Simulation Content Center Routed Systems: Tube & Pipe Autodesk DWF Markup Manager AEC Exchange Content Center Item Translator Frame Generator Simulation: Stress Analysis Drag & Drop Interoperability Design Accelerator Routed Systems: Cable & Harness AutoLimits Inventor Studio EDM Addin System Information: Operating System: 32-bit Windows XP Home Edition (5.1, Build 2600) Service Pack 3 (2600.xpsp_sp3_gdr.100216-1514) Language: English (Regional Setting: English) System Manufacturer: Sony Corporation System Model: PCV-RX860(UC) BIOS: Award Medallion BIOS v6.0 Processor: Intel® Pentium® 4 CPU 2.40GHz System Memory: 1536MB RAM Page File: 749MB used, 2684MB available DirectX Version: DirectX 9.0c (4.09.0000.0904) DxDiag Version: 5.03.2600.5512 Graphics Device Information: DirectX Version: 9.0c Renderer: HAL Adapter Description: RADEON 9800 PRO DDI Version: 9 (or higher) DDI Version Number: 9 DxDiag WHQL Level: 0 Driver Signed Valid: True Driver Signed: True Manufacturer: ATI Technologies Inc. Chip Type: ATI Radeon Graphics Processor AGP (0x4E48) DAC Type: Internal DAC(400MHz) Revision: Vendor ID string: 0x00001002 Device ID string: 0x00004e48 Graphics HW Memory: 256.0 MB Display Mode: 1024 x 768 (32 bit) (60Hz) VendorID: 1002 DeviceID: 4e48 SubSystemID: 2097148c Revision: 0 Graphics driver file: ati2dvag.dll Driver file version: 6.14.0010.6925 Driver Date: 2/11/2010 00:45:14 WHQL Level: 0 Inventor Graphics Device Information: Graphics Hardware Description: RADEON 9800 PRO Hardware Library ID: Direct3D \ 0x00001002 \ 0x00004e48 Direct3D Hardware ID: 1002 \ 4e48 \ 2097148c \ 0 Inventor Options Information: Options = 0x00000000 Warning Options = 0x00000000 Inventor Hardware Library Information: HW Library Version = $Revision: #1 $ HW Library Date = $DateTime: 2009/01/15 14:56:43 $ HW Library OS Name = Windows XP Inventor Hardware Library Entry Information: Autodesk Inventor Certification Status: Unknown Autodesk Inventor Tested Certification Status: Unknown Graphics HW Vendor Supported for Autodesk Inventor: False Hardware Library 2.0\0x00001002 Settings for optimized and conservative: Workarounds: 0x00000040, 0x00000040 rating 0, optimization level 2 Texture Font Precision: 32 Display Information: Back Buffer Format = A8R8G8B8 Depth Stencil Buffer Format = D24S8 Monochrome Bitmap Format = A8 Device Adapter Information: AdapterOrdinal = 0 MasterAdapterOrdinal = 0 AdapterOrdinalInGroup = 0 NumberOfAdaptersInGroup = 1 Device Processing Information: DeviceType = 1 Device Behavior = 0x00000042 Vertex Processing = Hardware Device Transform and Light = Hardware Device Rasterization = Hardware Supports SlopeScaleDepthBias = True Supports DepthBias = True Supports CubeMaps = True Supports Non-Power-Of-2 Textures = False Supports Non-Power-Of-2 Textures Conditionally = True Device Size Limits: MaxPrimitiveCount = 1048575 MaxVertexIndex = 16777215 MaxTextureWidth = 2048 MaxTextureHeight = 2048 MaxSimultaneousTextures = 8 NumSimultaneousRTs = 4 MaxActiveLights = 8 MaxUserClipPlanes = 6 Device Shader Information: VertexShaderVersion = 2.0 PixelShaderVersion = 2.0 MaxVertexShaderConst = 256 PixelShader1xMaxValue = 3.402823E+038 MaxVShaderInstructionsExecuted = 4294967295 MaxPShaderInstructionsExecuted = 0 MaxVertexShader30InstructionSlots = 0 MaxPixelShader30InstructionSlots = 0 VS20Caps = 0x00000000 DynamicFlowControlDepth = 0 NumTemps = 16 StaticFlowControlDepth = 1 PS20Caps = 0x00000000 DynamicFlowControlDepth = 0 NumTemps = 12 StaticFlowControlDepth = 0 NumInstructionSlots = 96 The Remainder of the Device Caps Information: Caps = 0x00020000 Caps2 = 0x60020000 Caps3 = 0x000003a0 PresentationIntervals = 0x80000001 CursorCaps = 0x00000001 DevCaps = 0x001bbef0 PrimitiveMiscCaps = 0x001b0cf2 RasterCaps = 0x0f736191 ZCmpCaps = 0x000000ff SrcBlendCaps = 0x00003fff DestBlendCaps = 0x00003bff AlphaCmpCaps = 0x000000ff ShadeCaps = 0x00084208 TextureCaps = 0x0007ed47 TextureFilterCaps = 0x07030700 CubeTextureFilterCaps = 0x03030300 VolumeTextureFilterCaps = 0x03030300 TextureAddressCaps = 0x00000037 VolumeTextureAddressCaps = 0x00000037 LineCaps = 0x0000001f MaxVolumeExtent = 1024 MaxTextureRepeat = 2048 MaxTextureAspectRatio = 2048 MaxAnisotropy = 16 StencilCaps = 0x000001ff FVFCaps = 0x00100008 TextureOpCaps = 0x03ffffff StretchRectFilterCaps = 0x03000300 VertexTextureFilterCaps = 0x00000000 MaxTextureBlendStages = 8 DeclTypes = 0x000000ff VertexProcessingCaps = 0x0000017b MaxVertexBlendMatrices = 4 MaxVertexBlendMatrixIndex = 0 MaxPointSize = 2.560000E+002 MaxStreams = 16 MaxStreamStride = 508 DevCaps2 = 0x00000071 MaxNpatchTessellationLevel = 1.000000E+000 MaxVertexW = 1.000000E+010 GuardBandLeft = -9.600000E+002 GuardBandTop = -9.600000E+002 GuardBandRight = 2.880000E+003 GuardBandBottom = 2.880000E+003 ExtentsAdjust = 0.000000E+000 Reserved5 = 0x00000000 Graphics driver log information: Quote
MarkFlayler Posted June 16, 2010 Posted June 16, 2010 What is the video card you are using? Has it been certified? http://www.inventor-certified.com/graphics/ If everything else is up to date I might try a repair on the install (this does not reinstall, it only replaces or add missing or modified files) Quote
MarkFlayler Posted June 16, 2010 Posted June 16, 2010 Also, there are three service packs for Inventor 2010, make sure you got them in too. http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9242019#section4 Quote
JimeeB Posted June 16, 2010 Author Posted June 16, 2010 Thanks Mark. I will find and install the SP and then try the repair option. It's just very strange as this is an intermittent problem. Quote
