Is it possible to set a default value for GETORIENT in something like this?
(setq rot1 (getorient "Specify angle..." ))
Thanks
Not sure if this is what you're asking for, but something like this may help:
(setq rot1 (if (setq tmp (getorient "Specify angle...")) tmp 0))
This will get the orientation, and if it exists, will set the variable rot1 to it. If it does not (say the user cancels out of it by right-clicking or what-have-you), then it will set rot1 to 0 instead.
Perfect, thanks - I think that will do what I need.
