Rhayes Posted September 2, 2008 Posted September 2, 2008 We are using AA-2008 I have several drawings with multiable viewports. that print out fine, until you save and then try and re-open. All the information is there in the drawing until you go to print, then some of the viewports disapear and will not print.???? Anyone else having this issue.? How do I keep this from happening again.??? Quote
Tiger Posted September 2, 2008 Posted September 2, 2008 is it just the viewport lines that are not printing or whats inside the viewport? If it's the viewport lines - is their layer set to Non-plot? Quote
Rhayes Posted September 2, 2008 Author Posted September 2, 2008 It's everything inside the viewport. It will show corect in paper space until you go to print then it goes away... Quote
NBC Posted September 2, 2008 Posted September 2, 2008 can you upload a small sample of the drawing in question ? Quote
ReMark Posted September 2, 2008 Posted September 2, 2008 Would it have anything to do with the MAXACTVP variable? Quote
Rhayes Posted September 3, 2008 Author Posted September 3, 2008 See attached. The only way that I have found to get the drawing to work is to do a purge and audit until all "Undefined Blocks" are gone Then I save the file and then it will print.??? Quote
