firavolla Posted June 18, 2010 Author Posted June 18, 2010 It worked!!!! Just had to set L to nil before the repeat cycle. Don't know why, but now it works. I didn't change anything else... Thanks, guys! Quote
alanjt Posted June 18, 2010 Posted June 18, 2010 '(h) a quoted list will not evaluate what's inside. You must use (list h) Quote
Se7en Posted June 18, 2010 Posted June 18, 2010 > Secondly, while is indeed a conditional loop. The problem i have with that label is that its so generic...you might as well just say that its a function. Yes, it is a loop based upon a condition; I know what it does. Im speaking and thinking more academically. Quote
Lee Mac Posted June 18, 2010 Posted June 18, 2010 Im speaking and thinking more academically. You've obviously got some knowledge beyond us mere mortals - what would you call it? Quote
Se7en Posted June 18, 2010 Posted June 18, 2010 You've obviously got some knowledge beyond us mere mortals - what would you call it? what? no. what makes you say that? If i knew what it was called i would call it that now wouldn't i? I want to try and to spend more time re-creating it. I was thinking about it last night on my way home and the only way i could re-create WHILE was with a simple linear recursive process (very simplistic). So ...I'm stumped (but them I am just a hack I want to talk to someone with a CS degree about it). Quote
Lee Mac Posted June 18, 2010 Posted June 18, 2010 The way I see it, is as just a repeated IF statement (minus the 'else' expression I suppose). Quote
Se7en Posted June 18, 2010 Posted June 18, 2010 yeah (well the else is the case but you get the idea). I imagined it a lot like MAPCAR -i.e. (defun map (proc items) (if (null items) nil (cons (proc (car items)) (map proc (cdr items))))) but passing an exit condition as well as checking for the end of the list. ...that cant be it though. It has to be different; WHILE is fast! MAPCAR is fast, but not that fast. *humm* Quote
Lee Mac Posted June 18, 2010 Posted June 18, 2010 I'm not sure MAPCAR is on the right lines, there is no test expression to terminate the recursion, all the 'items' will be processed. Quote
Se7en Posted June 18, 2010 Posted June 18, 2010 Thats why i said: "... but passing an exit condition as well". Quote
Freerefill Posted June 18, 2010 Posted June 18, 2010 I'm no CS major and I know as much about recursive loops as I do about string theory, but... Would this be a while loop represented as a recursive function? (defun whilerec(tst proc / ) (eval proc) (if (eval tst) (whilerec tst proc)) ) (defun c:tst( / ) (setq a 1) (whilerec '(/= a 10) '(progn (princ (strcat (itoa a) "\n")) (setq a (1+ a)))) ) Quote
Se7en Posted June 18, 2010 Posted June 18, 2010 That very well could. > ...I know as much about recursive loops as I do about string theory... A procedure can be recursive but the process a procedure uses can be recursive as well so you can have several different `recursive loop' scenario's: a recursive procedure using a recursive process, a recursive procedure using an iterative process. Have i posted my substitution model doc here? Quote
Freerefill Posted June 18, 2010 Posted June 18, 2010 I don't know if you have or haven't. I just googled "recursion" and got a stack error. Quote
Freerefill Posted June 18, 2010 Posted June 18, 2010 Yay for more of my useless drivel! Three loops re-written recursively! (defun whilerec(tst proc / ) (if (eval tst) (progn (eval proc) (whilerec tst proc)))) (defun repeatrec(tst proc / ) (if (> tst 0) (progn (eval proc) (repeatrec (1- tst) proc)))) (defun foreachrec(v lst proc / ) (if (set v (car lst)) (progn (eval proc) (foreachrec v (cdr lst) proc)))) (defun mapcarrec(fun lst / x) (if (setq x (car lst)) (cons (apply fun (list x)) (mapcarrec fun (cdr lst))))) (defun c:tstforc( / ) ;(foreach fv (list 1 2 3 4 5) (princ fv)) (foreachrec 'fv (list 1 2 3 4 5) '(princ fv)) (princ) ) (defun c:tstrepc( / a) (setq a 0) ;(repeatrec 5 '(princ (setq a (1+ a)))) (repeat 5 (princ (setq a (1+ a)))) (princ (list "*" a "*")) (princ) ) (defun c:tstwhilec( / b) (setq b 1) (whilerec '(/= b 10) '(progn (princ (itoa b)) (setq b (1+ b)))) ;(while (/= b 10) (princ (itoa b)) (setq b (1+ b))) (princ (list "*" b "*")) (princ) ) (defun c:tstmapc( / ) (princ (mapcar '(lambda (x) (1+ x)) '(0 1 2 3 4))) ;(princ (mapcarrec '(lambda (x) (1+ x)) '(0 1 2 3 4))) (princ) ) EDIT: And one more for mapcar. Quote
David Bethel Posted June 18, 2010 Posted June 18, 2010 How about a recursive conditional call:unsure: [b][color=BLACK]([/color][/b]defun nw_while [b][color=FUCHSIA]([/color][/b][b][color=FUCHSIA])[/color][/b] [b][color=FUCHSIA]([/color][/b]cond [b][color=NAVY]([/color][/b][b][color=MAROON]([/color][/b]setq input [b][color=GREEN]([/color][/b]getint [color=#2f4f4f]"\nNumber To Add: "[/color][b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]setq tmp [b][color=GREEN]([/color][/b]cons input tmp[b][color=GREEN])[/color][/b][b][color=MAROON])[/color][/b] [b][color=MAROON]([/color][/b]nw_while[b][color=MAROON])[/color][/b][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b] tmp[b][color=BLACK])[/color][/b] [b][color=BLACK]([/color][/b]setq tmp nil[b][color=BLACK])[/color][/b] [b][color=BLACK]([/color][/b]prin1 [b][color=FUCHSIA]([/color][/b]nw_while[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b] I always like the way a recursive call looks when you (trace) the call Entering NW_WHILE: Number To Add: 5 Entering NW_WHILE: Number To Add: 6 Entering NW_WHILE: Number To Add: 7 Entering NW_WHILE: Number To Add: 8 Entering NW_WHILE: Number To Add: Result: (8 7 6 5) Result: (8 7 6 5) Result: (8 7 6 5) Result: (8 7 6 5) Result: (8 7 6 5) (8 7 6 5) -David Quote
Lee Mac Posted June 18, 2010 Posted June 18, 2010 I suppose it could be slightly shortened (defun nw_while ( / input ) (cond ((setq input (getint "\nNumber To Add: ")) (cons input (nw_while))) ) ) (setq tmp nil) (prin1 (nw_while)) Quote
