harley558 Posted June 17, 2010 Posted June 17, 2010 Is there a way to have the welding symbols when placed on a drawing be the same scale as the dimensions you are using? When I click on the welding symbol icon and place the symbol I then have to go through scaling the symbol to come close to what my other dimensions are. Quote
edwinprakoso Posted June 18, 2010 Posted June 18, 2010 You need to create the symbol as an annotative block. Annotative block will adjust the size to your active scale. Quote
harley558 Posted June 18, 2010 Author Posted June 18, 2010 The symbol is already created within the welding symbol ANSI library. It sounds like doing the symbol then making it a annotative block is counter productive Quote
Geordie Posted June 20, 2010 Posted June 20, 2010 You can set the scale in Options, AM :Standards Quote
