mcjohn Posted June 17, 2010 Posted June 17, 2010 I'm Using Civil 3D 2010 and curious to know how to properly add contour labels to a surface (of contours). When I go surfaces-add surface labels-contour (single or multiple) and select where I want my label(s) all that appears is a 'tick' line drawn through the point I selected. Selected, this 'tick' is called a surface contour label group in the properties panel. Using a template someone created for his company that I'm using as practice I am able to follow the same procedures and proper contour elevation labels appear. But when using the default template only a tick appears. John Quote
ScribbleJ Posted June 17, 2010 Posted June 17, 2010 Check your 'Surface Style' in the settings tab to see if Elevations under Display are turned on and also check the layer that they are suppose to be on in the layer manager if the layer is frozen or turned off. Quote
mcjohn Posted June 17, 2010 Author Posted June 17, 2010 Doing so changes the entire drawing dark blue for some reason.. Quote
mcjohn Posted June 17, 2010 Author Posted June 17, 2010 Sorry should have listend to the last part of your suggestion; the contours were on a frozen layer. Thx! Quote
Tantoun Posted September 25, 2011 Posted September 25, 2011 (edited) I have a question : I need to know how can i put a contour label with comma like : 100.1, 100.2 100.3 , etc Thanx Edited September 25, 2011 by Tantoun MIstake Quote
Tantoun Posted September 25, 2011 Posted September 25, 2011 How can I put the resulat of my volume (CUt And FIll) text form in the area drawing ? Quote
CyberAngel Posted September 26, 2011 Posted September 26, 2011 I have a question :I need to know how can i put a contour label with comma like : 100.1, 100.2 100.3 , etc You'll have to go back to the contour label style. Edit the Contents of the Text and change the precision to 0.1 instead of 0. You'll also have to change the contour interval under the Contours tab of the surface style, if you haven't already. Quote
