JamFam Posted June 20, 2010 Posted June 20, 2010 Hi everyone. I am new to autoCAD 2010 and am trying to learn the parametric constraints tool. I have followed an online tutorial on how to apply certain constraints to objects but the problem I am having is that no matter what I do I just can't seem to get the Parameters Manager dialogue box to appear. Regardless of how many times I've tried the Parameters Manager dialogue box simply does not appear. The system variable is set to 1 (Show constraints) Can anyone help me figure out why the Parameters Manager dialogue box does NOT appear when pressed???? Thanks to all Quote
Pablo Ferral Posted June 21, 2010 Posted June 21, 2010 It's possible that the dialog is off the screen... Try this: http://lynn.blogs.com/lynn_allens_blog/2008/10/an-autocad-hi-2.html or this: http://lynn.blogs.com/lynn_allens_blog/2007/01/an_autocad_hip_.html Quote
JamFam Posted June 22, 2010 Author Posted June 22, 2010 Hello Pablo; I have checked your links and can say that the first did not yield any success. The second links advice was followed and still no success. I typed the CUI and then clicked on the 2D drafting and Annotation default (current drawing), then I selected the Ribbon tabs then parametric then parametric manage. Only two lines appear indicating that the Show is marked as Yes and it's orientation is docked. I can't figure this one out. Any more suggestions would be appreciated. Thanks JamFam Quote
JamFam Posted June 23, 2010 Author Posted June 23, 2010 Problem solved. I wish I could say I did something realy terrific and teach others about how to fix the problem but I can't. I opened the block editor and selected the Properties Manager and the dialogue box appeared. I went back into Model space and viola, it was accessible there also. So in short if you can't see it in model space try seeing it in block editor. Hey it worked for me!! Quote
Pablo Ferral Posted June 24, 2010 Posted June 24, 2010 Thanks very much for posting your findings! Quote
MAB Posted July 5, 2016 Posted July 5, 2016 Happened to me! i saved the drawings then it appeared Quote
