I appreciate everyones hard work and effort also. I wish I had more to contribute. I no nothing about lisp and don't even know where to go to school for it or were to start to learn these.
  • Replies 31
  • Efeezy
    9
  • alanjt
    8
  • Lee Mac
    8
  • Freerefill
    3
I admit my introduction to LISP was indeed in a classroom, but my co-worker CommandantBill (who occasionally posts here) learned the basics from me, in nothing but a few hours one afternoon. From there, it was simply applying them, getting used to them, and whenever he needed something new, he'd ask a question or look it up. He's as good as me now, if not better. So don't lose hope, just dig in and don't give up. ^.^
I learned form hanging out in the forums and reading.
Ditto :) :)
We made a mistake on this one.If anyone chooses to use Volume lisp and formats to architectural or engineering units it will come up with the wrong answer. If we format units are in decimal (inches) then divided by(12x12x12)=1728 to be correct for cubic feet.
using the converter formatted in arch or eng.
ExLxWxH=144” wrong
In decimal
LxWxH= 12x12x12=1728”
1728/1728= 1 cubic foot
(defun c:Volume ( / ent obj )
(vl-load-com)
(if (setq ent (car (entsel)))
(if (vlax-property-available-p
(setq obj (vlax-ename->vla-object ent)) 'Volume)
(alert (strcat "Volume: " (rtos (vla-get-Volume obj))))
(alert "Selected Object Does not have a Volume Property")
I just showed you how to get at the volume don't you go pinning this on me... :glare:
No good deed goes unpunished.
Sorry, wasn't trying to be a jerk. Was trying to show the right way to use it. I was wrong yesterday and didn't want anyone else to be wrong.
what is a good book or site to learn lisp? I want to learn in my spare time. I don't even know where to start. Buttons and macros are easy so far...
These are good sites to learn the very basics:
http://www.afralisp.net/
http://www.jefferypsanders.com/autolisptut.html
http://ronleigh.info/autolisp/index.htm
If you want to get more advanced or look at the general concepts behind programming itself:
http://augiru.augi.com/content/library/au07/data/paper/CP311-4.pdf
http://mitpress.mit.edu/sicp/full-text/book/book-Z-H-4.html
http://www.cs.cmu.edu/afs/cs.cmu.edu/project/ai-repository/ai/html/cltl/clm/node1.html
But really, you can learn a lot more from examples posted on the forums with the VLIDE help files as a reference.
Just dissect a few examples line by line, using the VLIDE as a reference and ask if you get stuck.
Lee
Nice Nice Thank You! Your The S#!t !!!!!
