Lord V Posted June 22, 2010 Posted June 22, 2010 Firstly I appologise if this is the wrong place to post this query.... I am using AutoCad 2008. I need to write a lisp that creates xdata for a polyline. However I appear to have fallen at the first hurdle as I get the following error: xdata Unknown command "XDATA" this is the line I put in the lisp: (command "xdata" "584.6633,523.6835" "field1" "real" "1234" "") When I type the command into CAD xdata runs fine, but when I try to run it via a lisp I get the above error. What am I missing here? This is just a test at the moment as the data for the lisp will be generated by excel (I have alot of data). However I obviously need a lisp that actually works first! Regards Lord V Quote
lpseifert Posted June 22, 2010 Posted June 22, 2010 The command Xdata is an Express tool command, their use within a lisp is iffy. You may want to look into using SetXData method (vla-setxdata.... It's described in Developer Documentation > ActiveX and VBA Reference > Methods BTW, the AutoLisp, VBA... forum would probably be a better place to post your question. Quote
Lord V Posted June 22, 2010 Author Posted June 22, 2010 cheers, that may do it.... Regards Lord V Quote
Lord V Posted June 22, 2010 Author Posted June 22, 2010 ok my brain is a little frazzled this afternoon . I need a line in a lisp to select all objects that have a common point (in this case the start point of a polyline and the insertion points of block attributes in order to turn them into a block) What should I be writting? Im ending up in a nightmare of ssget, ssadd and every other half remembered function. (re-learning lisp with a stinking head cold is never a great idea by the way) Quote
