I have VBA code to add a new layout.
What I need now is to be able set the default style, make sure the display plot styles is on as well make sure there is no pop up form.
Thats the first step. I also need to be able to remove the layout once I'm done with it using again VBA code.
So please if you can help with any of this much appreciate.
I don't know any VBA, but if you know how to send commands to the command line, you could use the -LAYOUT command.
Hey that will work for removing it :) But i need to some how create a new layout from either a template or load the exact commands in so the user doesn't have to click anything
Just use the delete method on the Layout item:
ThisDrawing.Layouts.Item("Layout1").Delete
  • 3 weeks later...
You may research importing/exporting layouts between drawings. It's an ACAD command I think as well, so send command or sendkeys may work
