bastymydawg Posted June 22, 2010 Share Posted June 22, 2010 Scenario : 2 dwg files, Interior of a simple bedroom with some furnitures (practice file from the training center), and the other one a simple wallclock hanged on a wall (created at my home PC). Problem : Regardless of PC Specs I've tried rendering both files here at home, the file coming from the training center rendered fine using high settings for a couple of minutes. BUT the other one which was created here at home takes a medium setting for almost 20+ minutes!! Is or Are there settings binded/migrated in a dwg file? the interior have much more elements compared to the one i have here at home, I was just wondering why it takes too long to render a simple wallclock rather than the interior of a bedroom? Quote Link to comment Share on other sites More sharing options...
bastymydawg Posted June 23, 2010 Author Share Posted June 23, 2010 knock knock!! shed some light please ^_^ Quote Link to comment Share on other sites More sharing options...
iskalipsi Posted June 23, 2010 Share Posted June 23, 2010 http://www.cadtutor.net/forum/showthread.php?t=48605 try reading this forum Quote Link to comment Share on other sites More sharing options...
Red333 Posted June 23, 2010 Share Posted June 23, 2010 Have you compared the render settings? Like final gather, global illumination, output size? Quote Link to comment Share on other sites More sharing options...
bastymydawg Posted June 25, 2010 Author Share Posted June 25, 2010 @red33 Yes, but i'll check it again... @eskalipsi thanks for this link,I'll try adjusting settings later. Quote Link to comment Share on other sites More sharing options...
Cad64 Posted June 25, 2010 Share Posted June 25, 2010 As Red suggested, you just have to compare the settings between the two files. There are too many variables to consider and it would be impossible for us to tell you what's wrong without actually seeing your settings, and your files. Can you post a screenshot of your Advanced Render Settings for both files? It might also help to see the rendered images of both files. Quote Link to comment Share on other sites More sharing options...
bastymydawg Posted June 27, 2010 Author Share Posted June 27, 2010 thanks for the help, i was able to resolve the problem, final gather on the other file is enabled. Quote Link to comment Share on other sites More sharing options...
