Apologies if I am not explaining these items very well
Jammie
you explained it very well. I will put the (if)statment back in and add the (princ "\nNo object selected"). Thanks for explaining it to me.
I copied your altered code but was unable to see any difference probably my fault, for sure. But I do see where you are going with it and this is a feature I do want.
Funny enough, I am starting to see what Lee Mac is talking about, where using commands can get messy. When I undo the vertex it only steps back one command inside the code not the entire code for vertex. Meaning that when I undo I don't get the full polly element back I get two broken lines, seperate elements. I have to undo several time to get back to the beginning
Goes to show you can advise anyone with anything but sometime a person can't see the meaning until they stumble upon it themself.
I have learned a lot from this post, Thanks to everybody.
  • Replies 22
  • cadman6735
    10
  • jammie
    8
  • Lee Mac
    3
  • alanjt
    1
Apologies, I have updated the last code, there was a slight bug in it
You are able to set a start and end mark for using the UNDO. This means that multiple commands between the start & end marker are undone at the one time
I have also added this to the previous code
Too true, its a great way of learning
Regards
Jammie
Jammie
Works like magic...
Thanks
