mcjohn Posted June 22, 2010 Posted June 22, 2010 Is there a way to convert a dwg autocad civil 2010 dwg file for an ESRI gis user to use? If it cannot be done in autocad are there (and what) programs to do so? Thanks! Quote
ScribbleJ Posted June 23, 2010 Posted June 23, 2010 ESRI ArcGIS can add AutoCad files as data in the original dwg format. There is also a tool within ArcGIS that will convert AutoCad files into shape files. Check the Toolbox in ArcMap or ArcCatalog under conversions. Quote
GaryMorin Posted June 30, 2010 Posted June 30, 2010 Sure, Civil has map functionality, you can save your data as SHP from within Civil, try Mapexport on the command line Quote
