mrthra Posted June 23, 2010 Posted June 23, 2010 Morning! Very simply, I have a drawing with houses and gardens in plan. I am writing a routine which will pick and extract the house number text then pick round area of the garden and write both to a text file. My problem is running the area command in Autolisp. As shown below, i start the area command and add a pause so i can pick round the perimeter of the garden. This doesnt seem to work?!! Any clues?? (command "area" pause) (setq aa (getvar "area") I use old skool lisp, so VBA is over my head! regards Quote
MSasu Posted June 23, 2010 Posted June 23, 2010 Try to list programmatically the area instead of using the command: (vl-load-com) (setq MyEntity (vlax-ename->vla-object MyEntity)) (if (vlax-property-available-p MyEntity "area") (vlax-get (vlax-ename->vla-object (entlast)) "area") 0.0 ) Regards Quote
mrthra Posted June 23, 2010 Author Posted June 23, 2010 Try to list programmatically the area instead of using the command: (vl-load-com) (setq MyEntity (vlax-ename->vla-object MyEntity)) (if (vlax-property-available-p MyEntity "area") (vlax-get (vlax-ename->vla-object (entlast)) "area") 0.0 ) Regards Thanks - however i want to pick points rather than select an object. Quote
alanjt Posted June 23, 2010 Posted June 23, 2010 So pick the points: (defun _Area (/ val) (setq val (getvar 'area)) (command "_.area") (while (< 0 (getvar 'cmdactive)) (progn (princ "\nSpecify point: ") (command PAUSE) ) ) (if (not (member (getvar 'area) (list val 0.))) (getvar 'area) ) ) Personally, I'd do it this way (minus use of command and plus nice display), but we'll keep things simple to begin with: Quote
