PointOfLight Posted June 23, 2010 Posted June 23, 2010 Is there any way I can make it so I'm able to snap to objects I've drawn in paper space while I'm working in a viewport in model space? Thanks Quote
ReMark Posted June 23, 2010 Posted June 23, 2010 I think you have to be in paper space to snap to objects in paper space. Quote
Tiger Posted June 23, 2010 Posted June 23, 2010 Not that I know of, you can do it the other way around though. The command CHSPACE might help you, it copies objects from Paper to Model space and scales accordingly. Quote
PointOfLight Posted June 23, 2010 Author Posted June 23, 2010 Thanks Tiger, that might help. I'm trying to put in blocks in one viewport and make them line up with the ones in another. Quote
Tiger Posted June 23, 2010 Posted June 23, 2010 You can use the MVSETUP command and ALIGN option to align points in viewports to each other. Quote
nukecad Posted June 23, 2010 Posted June 23, 2010 Look at the very unknown XLINE command. (It is a standard Autocad command but dosen't have its own toolbar). It extremely useful, and is a great help when lining things up. Quote
rkent Posted June 24, 2010 Posted June 24, 2010 Thanks Tiger, that might help.I'm trying to put in blocks in one viewport and make them line up with the ones in another. This is easy enough to do, you use the move command, pick a viewport, then pick on an endpoint of the block in that view, then use snap perpendicular to the block in the other viewport. Those were examples, use osnaps that make sense to you. And of course you can use osnaps and otracking. Quote
bonehead411 Posted June 24, 2010 Posted June 24, 2010 Look at the very unknown XLINE command. (It is a standard Autocad command but dosen't have its own toolbar). It extremely useful, and is a great help when lining things up. Seconded. Rarely a day goes by when I don't use construction lines for one thing or another. Quote
