FunkyFresh Posted June 23, 2010 Posted June 23, 2010 This has been a major problem we have and had to do a workaround that doesnt work as efficiently. How do you start autocad to create a drawing? The code we had (but didnt work properly): 'to start autocad and create an instance of it, it doesnt work however AcadApp = New Autodesk.AutoCAD.Interop.AcadApplication 'to open a specific file AcadDoc = AcadApp.Documents.Open("C:\contracts\test.dwg", False, "") Current System: AutoCAD 2010, Windows 7 64-bit. It works on autocad 2010, windows vista 32-bit fine. but not the windows 7 64-bit. Please take a look at this AutoDesk Quote
Tiger Posted June 24, 2010 Posted June 24, 2010 First of all, this forum is not Autodesk or in any way connected to Autodesk - if you want assistance from Autodesk, I suggest you go to their official website. Second, I have always thought that if you have a 64-bit system you need the AutoCAD for 64-bit - but I am not the go-to-guy for that. This list says that ACAD2010 is compatible with Windows 7 so that shouldn't be the problem. Quote
ReMark Posted June 24, 2010 Posted June 24, 2010 Tiger: You can run 32-bit apps on a 64-bit system. I currently have 2004 (32-bit) loaded on my 64-bit (Win7) desktop. I'm also running AutoCAD 2010 (64-bit) on this system as well. Quote
Tiger Posted June 24, 2010 Posted June 24, 2010 Tiger: You can run 32-bit apps on a 64-bit system. I currently have 2004 (32-bit) loaded on my 64-bit (Win7) desktop. I'm also running AutoCAD 2010 (64-bit) on this system as well. Then I have learnt something new today, can I go home then? Quote
ReMark Posted June 24, 2010 Posted June 24, 2010 Home? Didn't you just get in? What do work now, banker hours? Sure, why not. Have a sparkling day. Quote
Tiger Posted June 24, 2010 Posted June 24, 2010 Home? Didn't you just get in? What do work now, banker hours? Sure, why not. Have a sparkling day. I am 8 hours ahead of you you know, I was here before you went to bed :wink: Quote
chulse Posted June 28, 2010 Posted June 28, 2010 Tiger: You can run 32-bit apps on a 64-bit system. I currently have 2004 (32-bit) loaded on my 64-bit (Win7) desktop. I'm also running AutoCAD 2010 (64-bit) on this system as well. Mark, we are looking to replace an aged desktop - would you recommend Win 7, 64 bit? Quote
Skybeorn Posted June 28, 2010 Posted June 28, 2010 I would Go 64 bit. But thats my prefence, you will get more speed out of a 64 bit system. Quote
ReMark Posted June 28, 2010 Posted June 28, 2010 I would heartily recommend upgrading to a 64-bit system. The choice of operating system is up to you. I'd consider XP or Win7. I would not even consider Vista. If you cannot afford to spent a lot then keep the RAM to 4GB (maybe even drop down to 1066MHz) and look at using an entry level graphics card. Both can be upgraded in the future. Quote
chulse Posted June 28, 2010 Posted June 28, 2010 Thanks I have no experience with 64 bit. I hope to go for gold here so we'll see what I can get. Quote
ReMark Posted June 28, 2010 Posted June 28, 2010 32-bit and 64-bit Windows (OS) FAQ: http://windows.microsoft.com/en-US/windows-vista/32-bit-and-64-bit-Windows-frequently-asked-questions Quote
