mitchemj Posted June 24, 2010 Posted June 24, 2010 I'm trying to replace some existing blocks in a drawing with an updated block with a new name. Sometimes the command blockreplace will work, other times it does not. These are all dynamic blocks and have multiple visibility states. Any suggestions would be greatly appreciated. Thanks! Quote
Tommy78 Posted June 25, 2010 Posted June 25, 2010 After you replaced the blocks try the BATTMAN command and press sync, that seems to help sometimes Quote
woodman78 Posted August 6, 2010 Posted August 6, 2010 I had this problem recently and discovered it is to do with invalid characters in the block name. Bit of a dose. I would try one of the lisp routines for block replace and see do they work. Quote
