I am in the process of writing a routine to clean drawings that come from an outside source. What is happening is every once and awhile I will come across a drawing that is unstable and throws up the AutoCAD "Program Errors were detected. Recommend that you save your work and restart the program." Is there any way to prevent this in VBA from coming up, or is there a way to close it in VBA? Here is a snippet of the code that I have written.
Sub dwgclean()
 Set objFSO = New FileSystemObject
 Set objFolder = objFSO.GetFolder(Me.txtFolderSource.Text)
 For Each objFile In objFolder.Files
    If objFile.Type = "AutoCAD Drawing" Then
    WholeFile = Me.txtFolderSource.Text & "\" & objFile.Name
    AutoCAD.AcadApplication.Documents.Open WholeFile
       ThisDrawing.PurgeAll
       ThisDrawing.SendCommand ("-purge r *" & vbCr & "n" & vbCr)
       ThisDrawing.AuditInfo True
       "THIS IS WHERE I NEED THE DIALOGUE CLOSE!"
       RemoveLayerFilters
       DeletePageSetups
       DeleteScaleList
       ThisDrawing.SaveAs Me.txtFolderdestination.Text & "\" & objFile.Name
       ThisDrawing.Close
    End If
  Next
  deletebackup
End Sub
I have already tried the "nomutt", "expert", and "filedia" system variables with no help. If you need a drawing example let me know, and I will send it via email. Almost 10Mb... What would be ideal if I could somehow mimic the scriptpro ability to close dialogues.
mlabell
Is the code in a VBA form?
If so, you can use
Userform.hide
That will close the form and continue on
ML
Yes my code is in a form. But the error dialogue is an AutoCAD related dialogue when you audit a drawing several times to remove gunk. Whether the auditing done via script, lisp or vba the dialgoue is the standard warning to let the user know there is a drawing instability in the database.
My ultimate goal would be to incorporate a scriptpro type control where it supresses any AutoCAD dialogue boxes...
SendKeys "{ESC}"
That might work ASMI, good idea
After the line
put
SendKeys "{ESC}"
I believe that you said that you have tried filedia, set to 0?
Let me know if this still doesn't work, I can then try running the code.
I see that you are using FSO, I like that! I use it all of the time! : )
ML
If the aforementioned ideas don't work, then I can have you FTP the drawing to me, that won't be a problem
ML
would this apply to bypassing the popup from land desktop when a drawing is not associated with a project? i've been trying to bypass that forever.
Hi Alan
This is one way to find out :)
ML
sorry, i should have been a little more forthcoming. i don't know anything about vba; i only know lisp. i've been wanting to learn vba, but i just haven't really had the time, plus i read that it's going to be replaced with .net for autocad. i'd hate to go to the trouble of learning a language that is going to be obsolete in a year or 2 (in regards to autocad usage).
Hi Alan
I am the opposite, I know a fairly good deal with VB and very little with LISP.
As to whether or not VBA will go away altogether is yest to be seen, however, if you were to use VB.net down the road, I can tell you that knowing VBA will serve you a whole lot better then LISP.
Having said that, there are like 4 other languages in .net, so you may not even decide on VB down the road
ML
Hi Alan
ML
interesting to know.
yeah, i've been wanting to start learning a new language, but i want to choose one that will benefit me in more ways than just autocad. i've also considered C since i found out that it will work within autocad.
Hey Alan
Yes, you see, I have been doing VBA for about 5 years and VBscripting for almost 2 years, so it is almost a natural progression for me to dive into VB.net
If I do that, then I feel like I would have a wide spectrum of The VB family covered, while building more value for myself
In your case, since LISP is (for the most part) specific to ACAD, then it would be good for you to really think about which way you want to direct your energies.
VB 2008 (.net) has two versions of C language, they are
Visual C++ and Visual C#.
I don't know much about either, though I have heard good things about C#
Also, as Intermediate programming languages, in .net, you can program in C#, I can program in VB and we can still combine our code. So, that is pretty interesting.
You can download
Visual Studio 2008 Express Edition for free at
http://www.microsoft.com/express/vb/default.aspx
ML
Alanjt, there are lots of choices as far as which language to pick. VB.Net or C# are the 2 "easy" ones from Microsoft. C++ being the biggest undertaking, IMO, and the hardest to learn from what I have heard. But you can program Acad from other languages as well, like Python. There are threads showing all different ways to program Acad.
All that being said, I would pick one that has lots of examples to learn by. C#, C++, and VB.net have the most examples that I have seen. If I was going to pick, I would pick in that order. C# seems to be the way Autodesk is going, judging by the examples they are posting on the internet, and the topics being covered in webcasts.
Hope it helps
