I'm looking for a lisp to test if an element is repeated in a list and how many times.
e.g.
(A B C D A 1 2 12 2 XX)
A = 2
2 = 2
I've written this but ...
(setq kcnt 0)
(while (
(setq mcnt (+ 1 kcnt))
(while (
(if (= (nth kcnt fdp_BLK_NUM_LST) (nth mcnt fdp_BLK_NUM_LST))
(prc (strcat " La scatola # " (nth kcnt fdp_BLK_NUM_LST) " si ripete nel foglio di produzione"))
(setq fdp_errore_scatola 1)
));if
(setq mcnt (+ 1 mcnt))
);while
(setq kcnt (+ kcnt 1))
);while
(if (= fdp_errore_scatola 0)(prc " -- OK --"))
Thanks.
  • Replies 20
  • sadhu
    7
  • Lee Mac
    6
  • alanjt
    5
  • MSasu
    1
Maybe the code below will help you:
(setq ItemCounter 0)                            ;occurrencies counter set to 0
(while (member theItem theList)                 ;test if item belong to list
(setq theList (cdr (member theItem theList))   ;if found retain list after occurrence
      ItemCounter (1+ ItemCounter))            ; and index the counter
Regards,
I wrote this a while back...
(defun AT:ListDuplicates (lst)
 ;; Return all duplicates within list
 ;; lst - List to process
 ;; Alan J. Thompson, 11.01.09
 (vl-remove-if-not (function (lambda (x) (member x (cdr (member x lst))))) lst)
eg.
(at:listduplicates '(1 2 3 4 5 1 2 3)) -> [color=Red](1 2 3 1 2 3)[/color]
e.g.
A = 2
2 = 2
Thanks.
Here is my 2 cents
(defun count_occurs (lst)
 (if (car lst)
   (cons (cons (car lst)
 (length (vl-remove-if-not
         (eq x (car lst))))
    lst))
  (count_occurs
    (vl-remove-if
    (eq x (car lst))))
      lst)
~'J'~
I misunderstood the desired result...
(defun _ListDuplicateCount (lst / c new)
 ;; Alan J. Thompson, 06.25.10
 (foreach x (vl-remove-if-not (function (lambda (x) (member x (cdr (member x lst))))) lst)
   (if (setq c (assoc x new))
     (setq new (subst (cons x (+ (cdr c) 1)) c new))
     (setq new (append new (list (cons x 1))))
Thanks fixo
Thanks Alan
Thanks masau
You guys are of great help. :)
A little late, but will add my 5 cents
(defun mip_MakeUniqueMembersOfListWithCount  ( lst / OutList head countelt)
;; ===== mip_MakeUniqueMembersOfListWithCount =====
;; Removes the same (duplicate) items from the list
;; Quantifying the number of occurrences of an element
;; Use:
;; (Mip_MakeUniqueMembersOfListWithCount '(1 2 3 1 2 3 1 1 2 2))
;; Return ((1. 4) (2. 4) (3. 2))
 (while lst
   (setq head (car lst)
  countelt 0
         lst (vl-remove-if '(lambda(pt)(if (equal pt head 1e-6)(setq countelt (1+ countelt)) nil)) lst)
         OutList (append OutList (list (cons head countelt)))))
 OutList
(defun _ListDuplicateCounter (lst / c new)
 ;; Alan J. Thompson, 06.26.10
 (foreach x lst
     (setq new (subst (cons x (1+ (cdr c))) c new))
  • 2 weeks later...
Hi Alan,
I using this code
 (foreach x lst
like this
(defun c:repeat_test()
 (setq my_lst (list 1 2 3 4 5 6 6 1 1 2 2 3 3))
 (setq my_new_lst ( _ListDuplicateCounter my_lst))
 (princ my_new_lst)(princ)
and i get this fantastic result
((1 . 3) (2 . 3) (3 . 3) (4 . 1) (5 . 1) (6 . 2))
I need to distinguish items that repeat odd number of times (actually elements that repeat once, thrice and 5 times would suffice).
A result with the command "prc" - i print to a text file
"1" repeats 3
"2" repeats 3
"3" repeats 3
"4" repeats 1
"5" repeats 1
6 excluded and not printed.
thanks:roll:
Slightly late to the party, but my 2 cents:
(defun LM:ListDupes ( lst )
 ;; © Lee Mac 2010
 (if lst
   (if (vl-position (car lst) (cdr lst))
     (cons
       (cons (car lst)
         (- (length lst) (length (vl-remove (car lst) lst)))
       (LM:ListDupes (vl-remove (car lst) lst))
     (LM:ListDupes (cdr lst))
(vl-remove-if-not
 (function (lambda (x) (vl-position (car x) '(1 3 5))))
 (_ListDuplicateCounter my_lst)
Hi Alan,
I using this code
 (foreach x lst
like this
"1" repeats 3
"2" repeats 3
"3" repeats 3
"4" repeats 1
"5" repeats 1
thanks:roll:
 ;; © Lee Mac 2010
 (if lst
     (cons
       (cons (car lst)
(defun LM:GetOddDupes ( lst )
 ;; © Lee Mac 2010
 (vl-remove-if-not
   '(lambda ( x ) (= 1 (boole 1 1 (cdr x)))) (LM:ListDupes lst)
Alan,
I made this modification and does my case.
(vl-remove-if-not
 (function (lambda (x) (vl-position ([b][color=Red]cdr [/color][/b]x) '(1 3 5))))
Thanks a million.:D
Lee,
I tried your code like this - I get result nil - am I missing something ?:unsure:
 (setq my_lst (list 1 2 3 4 4 5))
 ;; © Lee Mac 2010
 (if lst
     (cons
       (cons (car lst)
 ;; © Lee Mac 2010
 (vl-remove-if-not
(LM:GetOddDupes my_lst))
Your list has only one element that is repeated twice - and hence it is omitted, as per your request.
My list has six elements with "4" repeated twice(even) so it should be excluded while 1, 2, 3 and 5 are present only once(odd) so they should be included :
I tried this way too and I still get nil:
(setq my_lst (list "1" "2" "3" "4" "4" "5"))
Sorry if I wasn't clear.:roll:
Ah - I thought you were counting only duplicates - my code ignores anything not repeated more than once.
That makes my code much simpler:
(defun LM:ListOccurrences ( lst )
 ;; © Lee Mac 2010
 (if lst
   (cons
     (cons (car lst)
     (LM:ListOccurrences (vl-remove (car lst) lst))
(defun LM:GetOddOccurrences ( lst )
 ;; © Lee Mac 2010
 (vl-remove-if-not
   '(lambda ( x ) (= 1 (boole 1 1 (cdr x)))) (LM:ListOccurrences lst)
Yes , now I got it. It works.
Thanks a lot Lee.:D
