When items selected props says "no selection"
Has anyone had this problem? When i select things the properties window says "no selection" so i cant change properties on that object, but the grips are highlighted and stuff? Any ideas?
Ok, messing around... Inserted an image, have it selected says no selection, same with all the polylines drawn by bringing in a field book. If i draw a polyline and select it it shows it being selected... wtf....
Im working in LD 2009, but if i open the same drawing in C3D 2010 it works fine.
