alanjt Posted August 2, 2010 Posted August 2, 2010 Alan,Great work. Exactly what I need. Thanks for your help and patience. You're welcome. Quote
kuttik Posted March 28, 2014 Posted March 28, 2014 OK so lets assume 6 texts are available in drawing A B C D E F .. A and B are close each other for example between distance is 10 and C and D are close each other for example between distance is 15 but both of them are far from A and B.. E and F are close each other and below of A-B and C-D texts. So lisp can be updated to combine A and B , C and D , E and F seperately when we select all of them in rectangular area?I mean not select one by one , when we select area lisp automatically selects texts which are close each other by defined distance ( for example 15) and combine them. Quote
kuttik Posted March 31, 2014 Posted March 31, 2014 I searched all forum topics still I couldnt how to solve Quote
Snownut Posted March 31, 2014 Posted March 31, 2014 Try these.... http://www.theswamp.org/index.php?topic=41223.msg463760#msg463760 there are a couple here. Quote
kuttik Posted March 31, 2014 Posted March 31, 2014 Actually I found that link , and i followed that topic and i have reached other topic link. And at last I have found one lisp, but that lisp as I understood automatically merge 2 texts which close each other as 2x height value of text. Thats ok . But lisp searches texts by Y alignment. I mean I select 2 texts in same horizontal line, lisp doesnt merge them. But if I select 2 texts in same or different vertical line ( within related distance 2xheight value ) lisp can merge texts. Which string should I change to make lisp can merge texts by X alignment not Y . I want to merge texts which are closer more than 2xheight value in horizontal line Here is code that I found ;; AUTHOR ;;; Copyright© 2010 Ron Perez (ronperez@gmail.com) ;;; 11.02.2010 added grouping text by X values (defun c:t2mt (/ rjp-removextraspaces rjp-ent2obj rjp-getbbwdth rjp-getbbtlc rjp-dxf d doc elst hgt i n nxt obj otxt out pt ss txt w x x_sort y ) (vl-load-com) (defun rjp-removextraspaces (txt) (while (vl-string-search " " txt) (setq txt (vl-string-subst " " " " txt))) txt ) (defun rjp-ent2obj (ent) (if (= (type ent) 'ename) (vlax-ename->vla-object ent) ent ) ) (defun rjp-dxf (code ent) (if (and ent (= (type ent) 'ename)) (cdr (assoc code (entget ent))) ) ) (defun rjp-getbb (ent / ll ur) (vla-getboundingbox (rjp-ent2obj ent) 'll 'ur) (mapcar 'vlax-safearray->list (list ll ur)) ) (defun rjp-getbbwdth (ent / out) (setq out (mapcar 'car (rjp-getbb (rjp-ent2obj ent)))) (abs (- (car out) (cadr out))) ) (defun rjp-getbbtlc (ent / out) (setq out (rjp-getbb (rjp-ent2obj ent))) (list (caar out) (cadr (last out)) 0.0) ) (if (and (setq ss (ssget ":L" (list '(0 . "text")))) (setq doc (vla-get-activedocument (vlax-get-acad-object))) ;;list as X Y TEXT ENAME (setq elst (mapcar '(lambda (x) (list (car (rjp-dxf 10 x)) (cadr (rjp-dxf 10 x)) (strcat (rjp-removextraspaces (rjp-dxf 1 x)) " ") x ) ) (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))) ) ) ) (progn ;;Sort top to bottom (setq elst (vl-sort elst '(lambda (y1 y2) (> (cadr y1) (cadr y2))))) ;;Group by x values using text height as fuzz value (while (setq i (car elst)) (setq y (vl-remove-if-not '(lambda (x) (equal (car i) (car x) (rjp-dxf 40 (last i)))) elst)) (mapcar '(lambda (x) (setq elst (vl-remove x elst))) y) (setq x_sort (cons y x_sort)) ) (foreach item x_sort (setq ;;Get widest piece of text to set mtext width w (* 1.0125 (car (vl-sort (mapcar 'rjp-getbbwdth (mapcar 'last item)) '>))) hgt (rjp-dxf 40 (last (car item))) pt (rjp-getbbtlc (last (car item))) ;;Grab top text to pull properties from otxt (vlax-ename->vla-object (last (car item))) ) ;;Puts hard returns for text spaced greater than (* 2. hgt) (setq n 0) (foreach x item (if (setq nxt (nth (setq n (1+ n)) item)) (if (>= (setq d (abs (- (cadr x) (cadr nxt)))) (* 2. hgt)) (setq out (cons (strcat (caddr x) "\\P\\P") out)) (setq out (cons (caddr x) out)) ) (setq out (cons (caddr x) out)) ) ) ;;Join the text into one string (setq txt (apply 'strcat (reverse out))) ;;Insert mtext (setq obj (vla-addmtext (if (= (getvar 'cvport) 1) (vla-get-paperspace doc) (vla-get-modelspace doc) ) (vlax-3d-point pt) w txt ) txt nil out nil ) ;;Match properties from top text object (vla-put-height obj (vla-get-height otxt)) (vla-put-attachmentpoint obj actopleft) (vlax-put obj 'insertionpoint pt) (vla-put-rotation obj 0.0) (vla-put-layer obj (vla-get-layer otxt)) (vla-put-stylename obj (vla-get-stylename otxt)) ;;Delete selected single line text (mapcar 'entdel (mapcar 'last item)) ) ) ) (princ) ) Quote
