I need to move an image in a drawing from a file my friend sent me. I also think he drew it in a different set up then what I did. We are doing a group project and I have to import his into mine. How do I do all of this?!?! I need help.
ok I figured out how to move it to my image. Now I need to re size the image but not the whole thing. I need it to move from left to right not up and down. Anyway to do this?
Put the image in MS Paint and change the attribute, width.
Good luck. What is the image of?
Use the BLOCK command and select your image as the object to include in the block.
Once you have the block created, click on it to select it and then Right Click and select Properties.
In the Properties palette, under "Geometry", change the "Scale X" value. This will stretch your image "left and right", but will not change it "up and down".
