Hi guys! im using 3dmax 2009 juts recently and found out that i have no materials on my materiallibrary folder.. i had downloaded many bitmap and jpeg images, the problem is, i cant put the materials on the object.... any help please...? diffuse-bitmap-etc... then apply it on the object, then nothing seems to work out, the object is still "gray"...
The object will continue to show its default gray color unless you click the "Show Standard Map in Viewport" button.
cad64... thank you so much! i totally forgot that eheheh:D... thanks again, its working now...
