DODGE Posted June 28, 2010 Posted June 28, 2010 Hi Guys Hows everybody going. Can somebody tell me how I lock a viewport in paperspace once I have got my drawing exactly how I want it. I quite often finish my drawing in model and then set her up in paper at the scale i want, Then sometimes I inadvertantly lose it. Cheers dodge8) Quote
Cad64 Posted June 28, 2010 Posted June 28, 2010 Click on your Viewport to select it and then right click, go to "Display Locked" and choose Yes. Or you can select the Viewport, open your Properties palette and lock the Viewport from there. Quote
DODGE Posted June 28, 2010 Author Posted June 28, 2010 Click on your Viewport to select it and then right click, go to "Display Locked" and choose Yes. Or you can select the Viewport, open your Properties palette and lock the Viewport from there. Cheers Cad I new it was something really easy, but I have never done it. Dodge Quote
profcad Posted June 29, 2010 Posted June 29, 2010 Just curious, why don't you scale and lock your viewport while you are inside the viewport? Select the scale from the viewport scale list on the status bar and then click on the padlock. 1 Quote
DODGE Posted June 29, 2010 Author Posted June 29, 2010 Just curious, why don't you scale and lock your viewport while you are inside the viewport? Select the scale from the viewport scale list on the status bar and then click on the padlock. Cheers for that. Geez I have never used that before. You learn something new everyday. Thanks for all your help. D Quote
profcad Posted June 29, 2010 Posted June 29, 2010 This capability (locking a viewport while inside it) was add in the 2009 version. Quote
gsksun4 Posted June 29, 2010 Posted June 29, 2010 Anybody know what the purpose of double clicking on the viewport frame is for other then zooming the viewport to extents? I get what looks like a thick red line as a viewport frame. Looks like a rope. Glenn 2009LT Quote
profcad Posted June 29, 2010 Posted June 29, 2010 gsksun4 - It allows you to maximize the viewport. This gives you a model space view while working in a viewport. The advantage of working in this mode is the ability to work in model space with all the layers frozen in the viewport. You can double click outside the "red rope" to minimize the view. 1 Quote
gsksun4 Posted June 30, 2010 Posted June 30, 2010 gsksun4 - It allows you to maximize the viewport. This gives you a model space view while working in a viewport. The advantage of working in this mode is the ability to work in model space with all the layers frozen in the viewport. You can double click outside the "red rope" to minimize the view. Thank you for the info. Glenn Quote
chulse Posted June 30, 2010 Posted June 30, 2010 I have a lisp (attached) that sets several variables and locks all viewports for me. Thanks to Lee Mac for putting it together. It locks ALL vports on every layout in one motion. psfix.lsp Quote
Alan Baker Posted July 2, 2025 Posted July 2, 2025 But how do you lock into paper space if you have zoomed in and cannot find the viewport edge to click on it? I have made a lot of changes and thought paper space was locked so now I cannot zoom out - the drawing is not locked? Quote
Cad64 Posted July 2, 2025 Posted July 2, 2025 Just type PS at the command line and hit Enter. That will switch you to paper space and then you can zoom out. 1 Quote
BIGAL Posted July 3, 2025 Posted July 3, 2025 You can make a selection set of all your viewports, and loop through them and set to locked. No user interaction. Done via a lisp. Now where did I put it. Also think make a new layout with a matching viewport at scale of a point picked in model space, the locking can be part of that program as suggested previously when making a viewport. Quote
SLW210 Posted July 3, 2025 Posted July 3, 2025 If you have it activated, there is a button on the bottom status bar for Model or Paper. Quote
