Frame Generator copying without vault
Hi everyone. new to forum and just wondered if one of you might be able to help.
When creating a frame in frame generator is it possible to copy the Weldment.iam and edit the copy using frame generator?
I have a simple standard frame and I want to be able to copy it and create a shorter version of it.
I've been suck with using just the copy components tool inside inventor as we havn't got Vault set up yet.
I've created a new assembly in a new window using the copy components tool, unticking resuse all std content centre parts and making everything (++) blue icon.
Then saving it in a seperate folder by selecting user path for each item (which I find tedious as I have to select each one individually).
This procedure has worked for me so far but with the downside to have to recreate all the .idw's. :glare:
Also anything created with frame generator doesn't link back to its sketch for some reason so I can't modify the weldment like I can with the master copy.
Will I have this problem when we get Vault set up?
Alex:wink:
