I've been creating a title block for 8.5x11 sheets and I'm looking to add the field that puts in the plot date/time in the corner. I'm trying to get the time in a 24hr format (as that is what I'm used to), but the only options I'm seeing in AutoCAD 2011 are for 12hr clocks. The AutoCAD help and Google hasn't been much help. Any suggestions?
In the Field dialog, Date and Time, the format column shows examples like 1:03PM and under that 13:03, pick that one or one like it.'
For date and time, first pick a date and time format closest to what you want, then in the date format at the center top change the lower case h with HH, pick OK, .....
Ah I see... that was far too easy, I should've seen that
