Hi all,
i am working on some civil projects in architectural dimension style.
when i get dimension this 'll shown as 7'-8" or 5'-6" etc. i wants this show as 7.6' or 5.5' etc. means only show feet not inches. any idea:?
Go to current dimension style (DIMSYLE command) and under Primary Units change unit format from Architectural to Engineering.
Regards,
Regards,
sorry not working...thsi is like as arch style no difference between arch n eng
Just saw that you want the value in feet, not in inch... Sorry for inconvenience.
For this case set the Unit Format to Decimal, use a Scale Factor of 0.08333 (1 / 12) and set the value of Suffix to ' (feet).
Regards,
You should start off a survey drawing with the following set up.
In Format > Units > Drawing Units > Length > Type = Decimal, Precision = 0.00, Insertion Scale = Feet
In Dimension Style > Modify > Primary Units > Unit Format = Decimal, Precision = 0.00, Round off = .00, Scale Factor = 1.00.
But if your insertion scale already = Inches, then your dimension scale factor will have to be .08333.
