How do I create a section view at a specific angle relative to a part.
I have attached a pdf of the part in question, im looking to project a section at the 20deg angle.
section.PDF
I dont have it open but I believe you just draw a line and add your dimension, then use that line for your section in the idw file. You can also create a section view in the model and save it to use in the idw i believe.
Zip and attach your ipt and idw (or dwg) file if you can't figure it out.
