Burner Posted June 30, 2010 Posted June 30, 2010 I used mvsetup to rotate viewports so the views fit my templates. Is there a way to align the text in the rotated viewport as well? The text is currently upside-down. Quote
rkent Posted June 30, 2010 Posted June 30, 2010 Select it all and use properties for your current situation. But there is no need to use MVSETUP. In 2010 you can rotate the viewport and the view will rotate with it, if VPROTATEASSOC is set to 1. You can set you text to align with the orientation, that is in the text style manager. Quote
Burner Posted June 30, 2010 Author Posted June 30, 2010 I basically want to flip the text with the dimension while maintaining the overall appearance. After selecting the appropriate dimensions, I can rotate the text within the properties menu, but the leader line in the small dimensions is distorted. It seems as if the insertion point is off. Suggestions? Quote
T2L Posted July 2, 2010 Posted July 2, 2010 While within the property menu, play around with the following: Text Text view directiion: Left to right / Right to left. Text pos vert: Text pos hor: And see what will happen to your dimensions. Quote
Burner Posted July 2, 2010 Author Posted July 2, 2010 Text pos hor & text vert seems to be grayed-out & locked on "centered" for all dimensions with leaders. Dimensions w/o leaders align just fine with this method. I am more concerned with appearance at this point. Quote
