I’m new to inventor and am trying to figure out how to toggle through selections with a key board shortcut. I find it slow using the arrows and selecting the green dot. It's a lot easier to do using AutoCAD.
Thanks
CAD911
You can scroll your mouse wheel too.
In the Application Options under the General tab and look at the bottom right under selection, you can change the delay time and speed it up as it scrolls through the selection.
Thank You
So I guess there are no keyboard short cuts for this.
Select other is automatic - no keyboard shortcut needed.
