Hi folks!
I am new here and I have a simple question.
I have to templates ready one is A4 and the other one is A1.
How can I draw a long rectangle (26000 mm) on that templates? How can I scale it down? I need millimeter resolution.
Thank you so much
Good luck
Draw the rectangle full size in model space. Switch to a layout. Create a viewport if one isn't already available. See your model? Now, scale the viewport. I recommend using the Viewports toolbar for this. When done plot the drawing at a plot scale of 1:1.
Refer to AutoCAD Help and your User's Guide for further details.
Thank you for the quick reply.
My problem is that if I draw a 26000 unit long rectangle in moldel space it is far too way long, I can't handle it. How would I get over it?
Thanks
You could draw the world's tallest building (Burj Dubai at almost 900 meters) in AutoCAD and it wouldn't be a problem. Your rectangle is just a flyspec in comparison.
