spittle Posted July 2, 2010 Posted July 2, 2010 Any ideas on how I can change this? A drawing produced by a client defaults to the imperial .lin file when loading linetypes, I want to set it so it looks for the metric one every time to avoid potential LT scale issues. Quote
dbroada Posted July 2, 2010 Posted July 2, 2010 to do it on your own files you need to set acadiso.lin rather than acad.lin to be the default linetype in your .dwt file. Unfortunately once the drawing is produced the linetype definition stays with it. As far as I know the only way round this is to reload all the linetypes, this time pointing to the correct definition file. This is possible with either a script or LISP. Maybe somebody will be along with a routine (or better advice) soon. Alternatively, send your .dwt to the client so that the drawing comes in correctly in the first place. Quote
chulse Posted August 25, 2010 Posted August 25, 2010 How do you go about changing the default .lin file that pops up when you try to load a new linetype? I'd like to set this to be my custom one and not the standard acad.lin... Quote
lpseifert Posted August 25, 2010 Posted August 25, 2010 I don't know if this is the best (or only) solution... You could try renaming acad.lin to something else (e.g. acad-orig.lin) and then rename your custom to acad.lin Quote
eldon Posted August 25, 2010 Posted August 25, 2010 One way to force AutoCAD to look for the correct Linetype file is to alter the system variable MEASUREMENT. If it is set to 0, it will default acad.lin, and if it is set to 1, it will default to acadiso.lin Quote
chulse Posted August 25, 2010 Posted August 25, 2010 Thanks all - looks like I need to rename my custom one. You would think it would be a file setting or sys variable somewhere... will need to make that suggestion to them. Quote
mdbdesign Posted August 25, 2010 Posted August 25, 2010 One way to force AutoCAD to look for the correct Linetype file is to alter the system variable MEASUREMENT. If it is set to 0, it will default acad.lin, and if it is set to 1, it will default to acadiso.lin Thanks Eldon, something new - never ending story with learning Autocad Quote
chulse Posted August 25, 2010 Posted August 25, 2010 ...never ending story with learning Autocad Isn't that the truth!! Quote
Daz Seaton Posted January 17, 2011 Posted January 17, 2011 One way to force AutoCAD to look for the correct Linetype file is to alter the system variable MEASUREMENT. If it is set to 0, it will default acad.lin, and if it is set to 1, it will default to acadiso.lin Thanks Eldon, just what i was looking for. Quote
