Treehugger Posted July 2, 2010 Posted July 2, 2010 I have just carried out a tree survey using a laser device and some GIS software. I have managed to upload the tree positions in DXF format but when I view the file in autocad the symbols representing the tree positions are very small squares that are difficult to discern. Is there any way that I change the symbols to something more discernable on the page? Sorry if this is a little unclear. I'm not really up on the technical jargon. Thanks in advance for any help. Quote
Tiger Posted July 2, 2010 Posted July 2, 2010 explore the variables PDMODE and PDSIZE - PDMODE changes the appearance of the points and PDSIZE the size. See your Help regarding the availible settings on PDMODE, I recommend 35 Quote
Treehugger Posted July 2, 2010 Author Posted July 2, 2010 Thanks for your quick response. I have messed about with PDMODE and PDSIZE to no effect. The current sybols look like a square with the numeral zero anchored to the bottom left hand corner of each square. Changing the PDMODEE and PDSIZE has no effect on the appearance of the symbol. I have selected the square and the zero separately and tried adjusting both to no avail. I presume this is because the square is already a symbol and not a point? Any clues Quote
Tiger Posted July 2, 2010 Posted July 2, 2010 Ah, so its a block? Try selecting all the blocks (QSELECT or FILTER or just Ctrl+A if its all there is) and changing scale in the Properties? Quote
Treehugger Posted July 2, 2010 Author Posted July 2, 2010 Thanks. This works but I would prefer it if the blocks were points (your suggested PDMODE 35 would be ideal). Is there anyway I can change them? Quote
Tiger Posted July 2, 2010 Posted July 2, 2010 Not change I would say, but you should be able to place a point at each Insertionpoint of the blocks.....this sound like a Lisp is needed though to make it efficient, but I don't know anything about Lisps Quote
Treehugger Posted July 2, 2010 Author Posted July 2, 2010 Fair enough Tiger. Thanks for your help. I will see if there is any adjustment that can be made in the GIS software to change the output. Quote
designerstuart Posted July 2, 2010 Posted July 2, 2010 don't need a lisp for this.... surely? you can just edit the block (BEDIT) to look how you want it and all the others will update, or make a new block and run BLOCKREPLACE to substitute them for another block of your choice. if you need all the blocks as they are, make a block containing your old block and a point (use the same base point) do BLOCKREPLACE, then explode them all. Voila - you have all original blocks in place, and a point over each one. Quote
Treehugger Posted July 2, 2010 Author Posted July 2, 2010 Hmmm thanks for the tip. Seems to be quite a complicated command. I am not really sure how to go about it. Quote
chulse Posted July 2, 2010 Posted July 2, 2010 What software created the dxf file? We use Trimble Pathfinder and there are some options for how the export is formatted... Quote
Treehugger Posted July 3, 2010 Author Posted July 3, 2010 Its software called PocketGIS and the tree positions were captured using a Trupulse 360. Quote
