doyle7700 Posted July 3, 2010 Posted July 3, 2010 Hi, I too just started using acad 2006 and can no longer just paste part of a cad drawing into solidworks like I used to be able to do when i used 2002 and r14 I really need this to work.. Can you or anyone offer any help? I simply want to edit, copy from autocad and past into my sketch in solidworks. I think there is a setting somewhere that needs to be changed???? thanks Quote
Cad64 Posted July 3, 2010 Posted July 3, 2010 I have removed your other duplicate thread from the Autocad section. Why don't you just Import your dwg into Solidworks, instead of copy and paste. Quote
shift1313 Posted July 3, 2010 Posted July 3, 2010 you can simply open your dwg in sw, no need to copy/paste. You can also create acad blocks and open them in SW. You mentioned your Acad version but what version of SolidWorks are you using. Quote
doyle7700 Posted July 5, 2010 Author Posted July 5, 2010 you can simply open your dwg in sw, no need to copy/paste. You can also create acad blocks and open them in SW. You mentioned your Acad version but what version of SolidWorks are you using. when i try to open the drg in solidworks I get a message saying Invalid/incomplete dwg dxf input file unable to continue import translation i'm using 2004 solidworks copy and paste result in no message and nothing happens hopefully this will help you Quote
shift1313 Posted July 5, 2010 Posted July 5, 2010 Well I dont think you can copy/paste between software like that. In SW go to your tools>add-ins and see if you have a dwg or dxf translator that isnt turned on. Quote
JD Mather Posted July 5, 2010 Posted July 5, 2010 You might try saving the DWG to earlier version since your AutoCAD is later version than your SolidWorks. Quote
doyle7700 Posted July 5, 2010 Author Posted July 5, 2010 You might try saving the DWG to earlier version since your AutoCAD is later version than your SolidWorks. i've tried that but when i save as an lower version in 2006 [ie r14 or 2000] i still have the problem Quote
doyle7700 Posted July 5, 2010 Author Posted July 5, 2010 Well I dont think you can copy/paste between software like that. In SW go to your tools>add-ins and see if you have a dwg or dxf translator that isnt turned on. I've gone to tools add ins but there is no dwgor dxf translator there Quote
