prasanth14026 Posted July 4, 2010 Posted July 4, 2010 Iam new to autodesk Inventor and i have installed inventor professional 2008. Presently iam using autocad 2008. Here i want to know is Analysis in Inventor. 1.I have a 3d model which was generated in autocad. 2.How i need to import in inventor. 3.Does this model will be in solid state? 4.What is the procedure to do analysis. 5.Where i can get the results after performing analysis. can anybody sent the tutorial or any video links to do it successfully. this is not for one time i need to do no.of times. Quote
JD Mather Posted July 4, 2010 Posted July 4, 2010 Iam new to autodesk Inventor. You should have posted your question in the Inventor forum, not the AutoCAD forum. http://www.cadtutor.net/forum/forumdisplay.php?f=32 You import an AutoCAD solid into Inventor by going to Open, select the filename and then Options and set to Import. It will be a solid in Inventor if Options set to Import. http://au.autodesk.com/?nd=class&session_id=3056 For analysis you need to go through the built it tutorials and http://www.amazon.com/Running-Autodesk-Inventor-Simulation-Step/dp/1856176940/ref=sr_1_7?ie=UTF8&s=books&qid=1278241709&sr=1-7 and http://store.autodesk.com/DRHM/servlet/ControllerServlet?Action=DisplayProductDetailsPage&SiteID=adsk&Locale=en_US&Env=BASE&productID=105089300 and sign up for a class. There are additional analysis classes here http://au.autodesk.com Quote
Cad64 Posted July 4, 2010 Posted July 4, 2010 Posting in the correct area of the forum will guarantee you the best possible help with your problem. This question has been moved to the Inventor forum. Quote
prasanth14026 Posted July 4, 2010 Author Posted July 4, 2010 sorry to every body, I really doesn't know that there is separate forum for inventor, From now and then it'll be maintain. Thanks to Mr.JD Mather for his reply, I'll reply once i go through it. Quote
