Hi,
Woke up to a serious problem in Autocad 2011.
Right/ double clicking does not do anythning except repaet the prev. command.
Now its impossible to edit nested blocks. or use the 'select similar' command.
right click custom. is set to "time sensi..." while edit node set to shortcut menu.
right-clicking in an empty space works....
right clicking on a selected object brings up the prev. command.
BLOCKEDITLOCK set to 0.
Thanks in advance.
Kev
Not impossible. You could always use the command line or toolbar buttons. :P
But seriously, check the setting of your PICKFIRST variable.
thanks.could not wait so I just reloaded. Thanks yopu anyway
Hi,
Thanks in advance.
Kev
Options, User Preferences, right-click customization.
And you can type BE for block edit, or left mouse double click on the block (should already be set to do that).
Selectsimilar - you can type Sel, hold shift, hit tab three times to find selectsimilar, hit return. Better yet go into the acad.pgp and set it to SS or whatever you want.
