dreamer Posted July 6, 2010 Share Posted July 6, 2010 Hi I try put a sphere in the middle of the box using filters. Followed every step of the example in Help many times. Every time the resulted sphere is in different places except in the middle of the box. Quote Link to comment Share on other sites More sharing options...
SEANT Posted July 6, 2010 Share Posted July 6, 2010 With you picture: Pick 2 for .x Pick 1 for .y Pick 3 for .z Quote Link to comment Share on other sites More sharing options...
dreamer Posted July 7, 2010 Author Share Posted July 7, 2010 It doesn't work either. What I can't understand also is every attempt the sphere is in different location. Quote Link to comment Share on other sites More sharing options...
SEANT Posted July 7, 2010 Share Posted July 7, 2010 It does sound like something is amiss with your setup. The only factor that I can think of is the OSNAPZ system variable, but that shouldn’t give any of the positions shown in your image. Are you saying that different positions are returned with picks in the exact same relative order? Quote Link to comment Share on other sites More sharing options...
dreamer Posted July 7, 2010 Author Share Posted July 7, 2010 Seant, thank you for your helping posts. I've found the cause of the trouble now - the DUCS was on. Quote Link to comment Share on other sites More sharing options...
SEANT Posted July 7, 2010 Share Posted July 7, 2010 That makes sense. It also makes sense that I would not have guessed that. I tried DUCS briefly, but found it too irritating to give it a second chance. Quote Link to comment Share on other sites More sharing options...
dreamer Posted July 8, 2010 Author Share Posted July 8, 2010 But it is a very useful feature when doing 3d modeling, particularly when you have to work on different UCS planes. Quote Link to comment Share on other sites More sharing options...
SEANT Posted July 8, 2010 Share Posted July 8, 2010 It is an issue of familiarity. I never determined how it set the origin for the new UCS, though I suppose that may become predictable with extended use. I still prefer to set the UCS with explicit origin via the 3PT option of the standard UCS command (its part of my default shortcut menu). Perhaps, now that the issue has resurfaced, I’ll give it another try. It is not good news, though, that it interferes with coordinate filters. Quote Link to comment Share on other sites More sharing options...
