comcu Posted September 4, 2008 Posted September 4, 2008 Hi, Is there away to freeze a vba project? sometime i dont want the project to work but i dont want to have to load and unload cheers, col Quote
CmdrDuh Posted September 4, 2008 Posted September 4, 2008 we need a little more info. Is it trying to run every time you open a dwg or close a dwg or what? Quote
rocheey Posted September 5, 2008 Posted September 5, 2008 put this in your form.initialize event do:loop that should freeze it up right. Quote
ML0940 Posted September 6, 2008 Posted September 6, 2008 If your code is Event driven, the below lines will work if put in the right place. ML Application.EnableEvents = False Application.EnableEvents = True Quote
comcu Posted September 9, 2008 Author Posted September 9, 2008 Thank you. I will try to implement you suggestions. cheers, col Quote
ML0940 Posted September 9, 2008 Posted September 9, 2008 Hey Col, I apologize, Application.EnableEvents = False and Application.EnableEvents = True are applicable in Excel but evidentially, not available in ACAD. That's ashame, that method can be very useful. I'm not sure how to suppress events in ACAD I'm sure a Google search could provide some incite. ML Quote
ML0940 Posted September 9, 2008 Posted September 9, 2008 Also, You never clarified what you meant by freeze a project? ML Quote
