Hi all,
Couple of questions
When translating from ACAD to Mstation some things don't quite get translated exact. I have narrowed down the issues but am still having problems, Mainly confussion in my head. Operator error!
So ignoring what I am doing above and here are my questions:
1. I want to explode all hatch patterns including nested hatch. How do I use (ssget) and (nentsel) together? Because I have hatch patterns that are inside of blocks.
Now I really don't want to explode the blocks because this will explode all the blocks including the ones with attributes, which I will loose if I do explode them. (I am curriouse of how to filter blocks with attributes from other blocks)
2. In my search for my answers I ran across the (qaflags) and found this site saying it is undocumented:
QAFLAGS been used a long time (
QAFLAGS acceps a value between 0 and 32767
bit 0 (1) : ^C in menu macro cancels grips (acts like keyboard
bit 1 (2) : no pause during text screen listings.
bit 2 (4) : no "alert" dialogs (text display instead).
bit 7 (128) : accepts "screen picks" (point lists) via (command) function.
Normally QAFLAGS should be set to 0. Because it might be set to other values it is a good idea to put (setvar "QAFLAGS" 0) in acaddoc.lsp or any other of your lisp files that you use for startup.
I found the above here:
http://www.jtbworld.com/autocadtips.htm
Can someone educate me more on this (qaflags) and the 32767 options that this can do?
But it is more important for me to understand question #1 for now.
Thanks
Forgot to add my code (this is what I have so far) seem logical (to me) but doesn't work on nested hatch
(defun C:exHATCH ()
(setvar "qaflags" 1)
(setq eINSERT (ssget "_X" '((0 . "HATCH"))))
(setq eINSERT (nentsel eINSERT)
(command "EXPLODE" eINSERT "")
(setvar "qaflags" 0)
also, since I am here
is there away to explode something in lisp without using the (command "explode") a backdoor way via dxf maybe or other way?
