I find layer state very useful. However, info from ACAD's Help concerning it was very limited. To access a layer state, I always need to pass at the usual Layer properties.. and click some icons. Is it possible to have an LISP or shortcut that will enable me to easily recall/restore a specific saved layer state? Say a command like RL1 (restores my layer state named as 1) and so on.. or similar scenario.
Thanks a lot! :)
I don't use layerstates, but:
(defun c:rl1 nil
 (vl-load-com)
 (layerstate-restore "1" nil nil)
Read the help files on the layerstate functions, I'm sure you could get somewhere. :)
Thanks for the reply and code, more power to you guys!
@Lee Mac: Thanks, but I think there's a problem with my CAD- an error message "no function definition" (see attached). I'm using 2007 version. What do you think?
Uploaded with ImageShack.us
The LayerState functions weren't introduced until '09, I think.
I was thinking I had some of these functions in my archive folder...
;;; Alan J. Thompson
;;; LayerStateSave Values
;;; Combine numeric values to use more than one (ie: 32+2+64)
;;; CONSTANT    LAYER PROPERTY        NUMERIC VALUE
;;; acLsAll        All            65535
;;; acLsColor        Color            32
;;; acLsFrozen        Frozen or thawed    2
;;; acLsLineType    Linetype        64
;;; acLsLineWeight    Lineweight        128
;;; acLsLocked        Locked or unlocked    4
;;; acLsNewViewport    New viewport layers     16
;;;             frozen or thawed
;;; acLsNone        None            0
;;; acLsOn        On or off        1
;;; acLsPlot        Plotting on or off    8
;;; acLsPlotStyle    Plot style        256
;;; LayerStateList
(defun LayerStateList (/ #List)
 (vlax-for x
           (vla-item (vla-getextensiondictionary
                       (vla-get-layers
                         (vla-get-activedocument (vlax-get-acad-object))
                       ) ;_ vla-get-layers
                     ) ;_ vla-getextensiondictionary
                     "ACAD_LAYERSTATES"
           ) ;_ vla-item
   (setq #List (cons (vla-get-name x) #List))
 ) ;_ vlax-for
 (reverse #List)
) ;_ defun
;;; LayerStateManager
(defun LayerStateManager (/)
 (or *LayerStateManager*
     (setq *LayerStateManager*
            (vla-getinterfaceobject
              (strcat
                "AutoCAD.AcadLayerStateManager."
                (itoa (fix (atof (getvar "acadver"))))
              ) ;_ strcat
            ) ;_ vla-getinterfaceobject
     ) ;_ setq
 ) ;_ or
 (vla-setdatabase
   *LayerStateManager*
   (vla-get-database
   ) ;_ vla-get-database
 ) ;_ vla-setdatabase
) ;_ defun
;;; LayerStateRelease
(defun LayerStateRelease (/)
 (not (vl-catch-all-error-p
        (vl-catch-all-apply
          'vlax-release-object
          (list *LayerStateManager*)
        ) ;_ vl-catch-all-apply
      ) ;_ vl-catch-all-error-p
 ) ;_ not
) ;_ defun
;;; LayerStateSave
(defun LayerStateSave (#Name #Prop)
 (LayerStateManager)
 (if
   (not
       (vl-catch-all-apply
         '(lambda ()
            (vlax-invoke-method *LayerStateManager* 'Save #Name #Prop)
          ) ;_ lambda
   ) ;_ not
    #Name
 ) ;_ if
) ;_ defun
;;; LayerStateRestore
(defun LayerStateRestore (#Name)
 (LayerStateManager)
 (if (not
         (vl-catch-all-apply
           '(lambda ()
              (vlax-invoke-method *LayerStateManager* 'Restore #Name)
            ) ;_ lambda
     ) ;_ not
   #Name
 ) ;_ if
) ;_ defun
;;; LayerStateDelete
(defun LayerStateDelete (#Name)
 (LayerStateManager)
 (if (not
         (vl-catch-all-apply
           '(lambda ()
              (vlax-invoke-method *LayerStateManager* 'Delete #Name)
            ) ;_ lambda
     ) ;_ not
   #Name
 ) ;_ if
) ;_ defun
I see, maybe that's why it isn't working on my current version. Thanks!
You're welcome. Try the above routines. I put those together while still running an older version of Acad.
You're welcome. Try the above routines. .
Thanks Alan, I'm a newbie sorry to ask but how will I use it, I mean what should I be typing at command line? are the words after "defun" means command? Thanks!
The functions Alan has kindly posted are 'subfunctions' or 'library functions' - these are not designed to be called straight from the command line but rather called from a program. Some will also take arguments (as is sometimes noted in code headers) - you will need to make sure that you supply the function with the correct number of arguments and argument type for the function to work correctly.
I see, thanks for the info.
